RR 08-01-2012 Release and PC Navigator 9
  • RR 08-01-2012 Release and PC Navigator 9
    Hi,
    Until now I used the 2012 june release of RR, and I use PC Navigator 9
    I start with the next skin sequence (without problems for a couple of years and previous releases of RR):
    B,200,3,136,120,"LOAD;navigator_gps.skin;Navigator ;C:\Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe;Nav igator"
    Today I update my RR to the 08-01-2012 release and whe I try to start PC Navigator nothing happens and didn't start
    I reinstall the june version and everything is working again
    is there anyone with this problem? and do you solve it?
    thanks & kind regards
    pc navigator isnt perfectly(and i use this term loosly) supported till 8/8 version of rr
    but i still feel if set up right it will work with 8/1
    i see from that load, your using the non free version right?
    debug.txt might shead some light
    also for window name better as "!MPFCWindow!Navigator"
    using the class will help make sure right window does embedd
    but not launching, is something in your load command
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      also, june is prob not aware of pc navigator
      review the history.txt
      so... 8/1 is for sure...
      only EVER tested with free ver
      also 8/8 has some key fixes for nav 11 and gps window ebedding in general
      and rr exiting tasks left running
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        I debug the RR and try with the two releases:
        -> RR 06-01-2012: Working
        24/08/2012 7:55:23: Enter Exec: False, audio_player.skin, "ONBTNPRESS||LOAD;navigator_gps.skin;Navigator;C:\ Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe;Nav igator", False
        24/08/2012 7:55:23: Que Exec: True, audio_player.skin, "ONBTNPRESS||LOAD;navigator_gps.skin;Navigator;C:\ Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe;Nav igator", False
        24/08/2012 7:55:23: Que Exec: True, audio_player.skin, "LOAD;navigator_gps.skin;Navigator;C:\Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe;Nav igator", False
        24/08/2012 7:55:23: Executing: LOAD;navigator_gps.skin;Navigator;C:\Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe;Nav igator
        24/08/2012 7:55:24: Que Exec: True, navigator_gps.skin, "ONSCREENCHANGE", False
        24/08/2012 7:55:24: Leave Exec: False, navigator_gps.skin, ONSCREENCHANGE, False
        24/08/2012 7:55:27: Enter Exec: False, navigator_gps.skin, "ONBTNPRESS||CANCEL", False
        24/08/2012 7:55:27: Que Exec: True, navigator_gps.skin, "ONBTNPRESS||CANCEL", False
        24/08/2012 7:55:27: Que Exec: True, navigator_gps.skin, "CANCEL", False
        24/08/2012 7:55:27: Executing: CANCEL
        -> RR 08-01-2012: NOT Working
        24/08/2012 7:59:31: Enter Exec: False, audio_player.skin, "ONBTNPRESS||LOAD;navigator_gps.skin;Navigator;C:\ Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe;Nav igator", False
        24/08/2012 7:59:31: Que Exec: True, audio_player.skin, "ONBTNPRESS||LOAD;navigator_gps.skin;Navigator;C:\ Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe;Nav igator", False
        24/08/2012 7:59:31: Que Exec: True, audio_player.skin, "LOAD;navigator_gps.skin;Navigator;C:\Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe;Nav igator", False
        24/08/2012 7:59:31: Executing: LOAD;navigator_gps.skin;Navigator;C:\Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe;Nav igator
        24/08/2012 7:59:34: Shell: "C:\Program Files (x86)\Navigator9\PC_Navigator\PC_Navigator.exe" --window_position=
        24/08/2012 7:59:34: Que Exec: True, navigator_gps.skin, "ONSCREENCHANGE", False
        24/08/2012 7:59:34: Leave Exec: False, navigator_gps.skin, ONSCREENCHANGE, False
        24/08/2012 7:59:35: Enter Exec: False, navigator_gps.skin, "ONBTNPRESS||CANCEL", False
        24/08/2012 7:59:35: Que Exec: True, navigator_gps.skin, "ONBTNPRESS||CANCEL", False
        24/08/2012 7:59:35: Que Exec: True, navigator_gps.skin, "CANCEL", False
        24/08/2012 7:59:35: Executing: CANCEL
        in the new RR version, appears a new line:
        there is a "--window_position=" that is not in the skin
        the skin is the same we have for many years:
        also I tried with "!MPFCWindow!Navigator" with the same result
        thanks & regards
          Some more info
          Navigator is the non free version
          the gps skin is:
          RideRunner Skin
          RRScreen external_gps
          /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
          L,7,10,179,050,255,255,255,18,"Tahoma","TIME","Tim e"
          L,8,60,183,050,255,255,255,18,"Tahoma","DATE","Dat e"
          L,302,040,724,82,255,128,0,32,"Tahoma:B","TAGARTIS T||= - ||TAGALBUM||= - ||TAGTITLE","SCROLL"
          /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
          B,1034,0,83,120,"PREV","PREV"
          B,1117,0,083,120,"PLAY","PLAY"
          B,1200,0,080,120,"NEXT","NEXT"
          B,201,0,136,120,"CANCEL",""
          /, A, x, y, w, h, color R;RGB, G, B
          A,0,120,1280,840,
          C,0,120,1280,840,
          END
          regards
            yes... the window position is to tell the program where to go
            and since its blank... thats prob the issue
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              Try removing the "C" line - we kind of integrated PC Navigator into RR and the C line would likely make it "disappear" since it's nicely into the skin now.
              Ride Runner RR's Myspace
                I tried without the "C" line and the result is the same
                thanks
                  That is definitely interesting, I'd like to have a closer look at this, I just don't have the "paid" version to test with. Any chance you'd be available for a remote connection session ? PM me if you can do that. Then I should be able to have a closer look and adjust it.
                    he is fixed with current rr
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      with the september version runs perfectly
                      thanks
                        Last update:
                        I upgrade to PC Navigator 12 (not free) and works perfectly
                        the free version is the same version as the non free, the unique difference are the maps
                        regards
                          Originally posted by kocke View Post
                          Last update:
                          regards
                          A little of topic but how are the paid maps in navigator12, are they up to date ?
                          The road is long but we are getting there.
                            very update, this is why I upgrade navigator 9
                            regards
                              where did you find navigator12, I can only see navigator11 in there website ?
