RR 09-01-2012 Release
  • RR 09-01-2012 Release
    Back to School folks (well at least here in the US)...
    Download from: http://www.nisuautomotive.com
    A bunch of little things, some VERY important thou...
    Highlights:
    • Better PC Navigator Support - Including in RRConfig
    • Added Direct Mixer control for plugin developers
    • Added dot Net Extension Plugin frm Object.txt document for c# plugin developers
    • Fixed some minor bugs, that has gone unoticed
    HISTORY:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    8/27/2012
    # Fixed issue with Lists with icons, if icons are invalid file paths
    * Changed so RR ignores unexecuted events with parameters like ONxxx;yyy
    8/20/2012
    + Added to SDK New Methods for direct Mixer Control (MIXER LINES ONLY)
      GetMixerMute(MixerLine as String) as boolean
      SetMixerMute(MixerLine as String, State as boolean
      GetMixerVol(MixerLine as String) as integer (0 - 100)
      SetMixerVol(MixerLine as String, Level as integer) (Level = 0 - 100)
      ex. SetMixerVol("Rear Blue In", 50)
    + Updated plugin examples SDK for new direct Mixer Control
    + Added Standard Status label for Sirius and XM
    # Fixed Active Source Label in Sirius mode
    # Fixed MediaList support for Sirius/XM when not using ID3 Tags
    # Fixed NonGesture Areas checks on Menus
    * Updated Carwings Dynamic skin (GPS Menu and some Phone indicator)
    * Updated Mappoint plugin for Mappoint 2010
    8/16/2012
    + Logging in the RUNxxx commands when the path is invalid or file is missing
    8/13/2012
    * Minor prevention against ONINVALIDCOMMAND for plugin issued events
    8/7/2012
    + Properlly close PC Navigator 11 on exit of RR
      note: PC navigator or iguidance window title is NOT required in embedded app list
            but the close app on RR close setting is followed (subject to change)
    + Setting; "GPSMode=4" is for PC Navigator 11 (allows for future integration).
    + Skin Command; "GPS", when in GPSMODE=4 will look for "pcnavigator_gps.skin",
                    falls back to "external_gps.skin".
    + Settings; "RRPCNavigatorPath=" & "RRPCNavigtorName="
        Note: RRConfig v1.0.12 now support PC Navigator and automates said settings.
    8/6/2012
    + Preserve CL.TAG on "RELOADSCREEN" (internal)
    8/4/2012
    # Fixed PC Navigator support when scaling skins (for some regional settings)
    + Added Extension Plugin example in Delphi
    8/1/2012
    + Skin Indicator; "vol;xxx" will also accept index, see debug.txt for valid indexes.
      ex. "vol;2"
    + Skin Indicator; "mute;xxx" is an alias of indicator "vol;xxx".
    + Skin Command; "Mute;xxx" will also accept index, see debug.txt for valid indexes.
      ex. "Mute;2"
    + frm.CL properties exposed to com to aid plugin developers.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thanks again for another RR Release mitch!
    Live mp3Car Facebook Chat
      +1 thanks for the work and the results!
        Since RR 1/1/2012
        RR not wait to load many songs to playlist when RR start..
        RR 12/1/2011 work ..Its wait for complete to load songs to playlist...and then resume..
          thanks for another RR release..
            Originally posted by anuchit View Post
            Since RR 1/1/2012
            winamp? foobar?
            attach a debug.txt
            work with a small amount of items too
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              Thanks for this new version
                Just installed this on my work machine (slow day and want to tweak some more).
                Noticed that the menu popups, if you specify a /POSY, it's now a definitive position, rather than from the middle of the screen.
                Before I had /POSY=-40, and now I have to have /POSY=338 for it to show up near the same position - haven't confirmed the numbers, but you can see the difference. Same is true for /POSX
                Not sure if this was one of those bugs gone unnoticed or a side-effect of something else. Either way I like this method much better; easier to deal with.
                *edit before it wasn't actually the position from the middle, but either way my files have all been modified now.
                03 Hyundai Elantra GT {Worklog}
                HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
                RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
                cmdRR tall skin creator
                86 Pontiac Fiero SE 2m6
                possible carpc install
                  yes.. i believe it was a long time bug... that Gunio fixed...
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
