Shutdown the PC by Powerbutton not working
  • Shutdown the PC by Powerbutton not working
    Hello
    If RR is running, my PC does not accept the Power-Button to shutdown. After closing RR, the PC shuts down by triggering the Power-Button.
    Is there an option to config? I can't find anything.
    RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
    RR-Plugin: IBusCommunicatoRR new Updates
    Likely there's some application running that is preventing it, but it is unlikely RR itself as most people (including myself) use some sort of shutdown controller that basically pushes the power button when you turn off the ignition (to initiate the shutdown). This could be a winamp plugin or even something messing with the power configuration. You may want to check the debug log as it would also indicate if there was any notification of shutdown attempts. It is also a known fact that in Vista/Win7 applications can not prevent the OS from shutting down or hibernating so I assume you're using windows XP - if this is the case I believe you can also modify some registry settings to not allow applications to prevent a shutdown attempt, but if it's something messing with the power configuration (i.e. to set the power button action to "none") then the only solution is to figure out what's doing it and remove/adjust it. If you want to verify RR doesn't 'block' the shutdown, you can simply run RR then while it's running click start->Shutdown and you'll see RR will not prevent it (There's no difference between that shutdown and the one initiated by windows when you press the power button).
    Ride Runner RR's Myspace
      some news. if i start the pc -> RR starts.
      first after touching the screen or some button on my BMW-Monitor send commands through IBus to RR does the PC shutting down by push the power button.
