RR 10-01-2012 Release
  • RR 10-01-2012 Release
    Hello Fall, what a fast summer eh?
    Download from: http://www.nisuautomotive.com
    not much this month, a bunch small tweaks, some for Windows 8.
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    9/15/2012
    * Prevention against flicker on Win8 when not using transitions
    # Fix for "MINIMIZE" not always hiding gestures
    9/12/2012
    + Windows 8 for "OSVERSION" Skin Label
    + Uservar; "IsWin8"
    9/11/2012
    + Support for "ByVar" command in sliders (set)
    9/8/2012
    * Tweak to PCNavigator window embedd options
      use "AX" ex. AX,x,y,w,h,"OPT_NOTOUCH,OPT_PARENT"
      this will parent PCNavigator to RR Window, may be used in somecases
    9/7/2012
    * Increased definition of debug log time format
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thank you, Mitch, for your dedication to RR, I think it is often taken for granted around here that RR is just always here and fresh. I can only imagine how much effort must be required to stay on a monthly schedule. Hell, there's paid FE out there that don't have an update schedule that rigorous....
    I'm 6 months behind on RR due to "life" getting in the way this summer. I look forward to trying dynamic menus, I am still running the last version prior to it.
      Thank you Mitch..
      Can U help me about taskbar on win8
      I want to disable taskbar always ontop..Somtime I use external app its popup on taskbar..
        anuchit, im not running win 8 (yet) only on virtual machine, and i dont know too much about it
        hiding the taskbar may not work the same, as the task bar is differnt from win7
        eventually when i switch to win8, maybe then i can look
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          win7 I use this..
          http://www.sevenforums.com/tutorials...le-enable.html
            Ok Mitch...
            Now I fix it by Taskbar Masher ...on win8
            http://www.csparks.com/Win7TaskbarMasher/
              Is it possible to create into the novembre RR version a little option for the indicator that invert the status as it's possible for the sliders with the 'R' option ?
              ex:
              I,377,130,30,37,"RRCORETEMP_MAXTEMP_ALARM:BR",500,500,"RRCoreTemp\INDICATORS\LED_RED_*.png "
                ex:
                + Indicator codes support NOT(invert) functionality
                ex. I,x,y,h,w,"MUTE" is TRUE when master volume is muted
                I,x,y,h,w,"-MUTE" is FALSE when master volume is muted
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  Cool, it try that as soon as possible !
                  Thanks Mitchjs
                    Thanks for the update!
                    Keep the good work!
                      For the next relase could be added, on the code for embeding application, the window trasparency? (like on visualization) would be usefoul for example use a normal button again instead of the region (that isn't precise on click), just make the windows 99% (with 1% of trasparence).
                      And could be added also support for the linein under the vector of activesources?
                      Thanks so much
                        Mitch please see debug log file from RR 12/01/2011
                        I like old this version because...I test by load many Flac songs amount tree hundred of songs in playlist..( hard test )
                        and when I run RR again it play resume from last song..so good,fast very well and corrected..
                        But newer from this version can't do that...newer from this version not play resume or play last position of song
                        I want to you test again
                        debug.txt
                        RideRunner Setup01122011.zip
                          generally i dont go backwards... only forwards...
                          far i as i know no changes to foobar code in months, but your going back almost a year
                          so i would compare a debug.txt of current version to that version...
                          it takes foo, very long to process the list of songs, so it is possible, that it hasnt processed the list
                          when rr asks it to play
                          just checked the last time foobar player was touched is 6/11/2011
                          so... its not the player... there has been changes in rr... specially for custom sources, so start up has been changed
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            Your debug seems to show the player resuming the song within 4 seconds of starting RR. Like Mitch said, we haven't changed anything in the player plugin for over 1 year. I don't believe we have changed enough in RR lately to cause any problems - was this working on RR in the September version?
                            Ride Runner RR's Myspace
                              I keep the Old West in length compared each month. To see the difference. I have no technical knowledge. But I noticed that Version is now waiting for it to be successful rrpl continuous music playback. But Version new length. It does not wait until the rrpl success. I just want to the RR load rrpl complete before onsongstart to resume Thanks for the answer.
