show and sort playlist by filename
  • show and sort playlist by filename
    Hi
    Is it possible to sort the audiofiles in playlist by filename?
    Is it possible to show in Playing-Tag the filename? winamp could handle that, butt RR not.
    regards
    RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
    RR-Plugin: IBusCommunicatoRR new Updates
    Just disable ID3 tags in RRConfig and everything will be done by filename - I do that myself because it's faster and less work to manage the music library.
    Ride Runner RR's Myspace
      ID3Tag is disabled.
      RR shows on Playlist just tracktitle.
      RR sorts the tracks by i don't know.
      in RR config i use for audiobrowser "$filepart(%filename%)", so i can see the filenames sorted by name. But playlist :-(
        set titlesafter= (blank) you probably "think" it's not sorted by filename because you're not seeing the whole filename.
          no, RR sorts file not like in explorer by name in playlist :-(
          i had test some methods -> no success
          but i find a workflow: i have to integrate the audiobrowser list to audioplayer. because, if i select a file in the browser RR adds the files by name.
          just one problem, RR adds alle files in folders under itself
          edit: fck it's not possible to integrate the browserlist on player :-((((((
          why is it so difficult to get simple filenames in playlist and label???
          is there a issui to add only the files in active folder?
            Maybe you want to pm me with a video showing your filenames and how they are displayed in RR browser and playlist. I use this everyday and I only use filenames - did you even try the titlesafter setting ? You may also play songs 'directly' from the file browser - some older skins (and maybe DFX if I recall correctly) had a screen which you'd just play music straight from the browser without using a playlist - this is possible and entirely up to the skinner.
