MediaList playlist, id3tags and id3ListFormat
  • MediaList playlist, id3tags and id3ListFormat
    Hello,
    I have and audio_player.skin with a IL and a Medialist:
    IL,PL,RGB000000,RGB000000,________________________ _______________________________________,2,50,80
    ML,PL,"%SColr=#000000%%Color=#FFFFFF%%TextW=800%%T ITLE%%TextY=34%%Font=Tahoma:20:B%%Color=#909090%%T extW=800%%ARTIST%, %ALBUM%",300
    S,234,240,814,712,255,255,255,0,0,0,0,255,0,255,12 8,0,0,0,0,,20,"Tahoma:B"
    also there is a Label for the current song with a tagartist, tagalbum, tagtitle
    at rr.ini the tag section is:
    [Audio Player - Tags & Formatting]
    UseID3=2
    ShowID3Playlist=True
    ShowID3Browse=True
    LazyTag=False
    ID3ListFormat=%artist% - %album% - %title%
    ID3BrowseFormat=%artist% - %album% - %title%
    NoFormat=False
    ListNumbers=False
    TitlesAfter=
    ScrollMode=1
    That's works very well
    the problem appears when I do a playlist with a skin with a Directory List and with the commands CLEARLIST, SELECT+ and SAVELIST. The new playlist allways have a #EXTINF at the first song, like this:
    #EXTM3U
    #EXTINF:0,Acoustic Alchemy - Against The Grain - Against The Grain
    C:\Musica\Mp3\Acoustic Alchemy\Against The Grain\01 Against The Grain.mp3
    C:\Musica\Mp3\Acoustic Alchemy\Against The Grain\02 Lazeez.mp3
    C:\Musica\Mp3\Acoustic Alchemy\Against The Grain\03 A Different Kind of Freedom.mp3
    C:\Musica\Mp3\Acoustic Alchemy\Against The Grain\04 Lady Lynda.mp3
    when I load that list at the audio_player.skin with the medialist, then the first song at the medialist appears with:
    title: Acoustic Alchemy - Against The Grain - Against The Grain
    album: "blank"
    artist: "blank"
    the other ones lines are correct.
    and the current song tagartist, tagalbum, tagtitle are blank
    is possible to generate the playlist without the #extinf?
    Trying diferent ID3ListFormat, I can see that the #EXTINF is constructed with that information
    When I try with
    ID3ListFormat=
    then the playlist is:
    #EXTM3U
    #EXTINF:0,
    the playlist loads perfect at the audio_player.skin
    But when I scroll down the medialist (or play next, with random), the other lines (different to the line the song is played) have the title with the filename of the song (instead of the title tag) and the artist and album tags are blank. when I browse that list up and down again, then refresh with the correct tags, but I need to browse some times or exit the skin and reenter. then when I go to a new section of the medialist, wich I didn't browse before, again the list is visualized wrong.
    thanks and regards
    What worked for me on the playlists was to open them in notepad and check to see if the path is correct.
    Yes, I use Winamp to make the playlist, on the computer that I am actually using, but it looks like this:
    #EXTM3U
    #EXTINF:208,AC/DC - Highway to Hell
    \Music\AC-DC\Highway To Hell\01 Highway to Hell.mp3
    #EXTINF:202,AC/DC - Girls Got Rhythm
    \Music\AC-DC\Highway To Hell\02 Girls Got Rhythm.mp3
    #EXTINF:309,AC/DC - Walk All Over You
    \Music\AC-DC\Highway To Hell\03 Walk All Over You.mp3
    #EXTINF:265,AC/DC - Touch Too Much
    \Music\AC-DC\Highway To Hell\04 Touch Too Much.mp3
    #EXTINF:235,AC/DC - Beating Around the Bush
    \Music\AC-DC\Highway To Hell\05 Beating Around the Bush.mp3
    #EXTINF:202,AC/DC - Shot Down in Flames
    \Music\AC-DC\Highway To Hell\06 Shot Down in Flames.mp3
    #EXTINF:154,AC/DC - Get It Hot
    \Music\AC-DC\Highway To Hell\07 Get It Hot.mp3
    \Music\AC-DC\Highway To Hell\08 If You Want Blood (You've Got It).mp3
    \Music\AC-DC\Highway To Hell\09 Love Hungry Man.mp3
    \Music\AC-DC\Highway To Hell\10 Night Prowler.mp3
    If I try to run that playlist in RR, it does not work.
    My complete path to the songs is D:\Music\AC-DC......
    So I open it in notepad, do a find and replace on "\Music" replacing it with "D:\Music". That's what makes it work. The path must be complete and explicit.
    For good measure I also get rid of all the lines that start with #EXTINF:....They are not needed. So a good playlist looks like this.
    #EXTM3U
    D:\Music\AC-DC\Highway To Hell\01 Highway to Hell.mp3
    D:\Music\AC-DC\Highway To Hell\02 Girls Got Rhythm.mp3
    D:\Music\AC-DC\Highway To Hell\03 Walk All Over You.mp3
    D:\Music\AC-DC\Highway To Hell\04 Touch Too Much.mp3
    D:\Music\AC-DC\Highway To Hell\05 Beating Around the Bush.mp3
    D:\Music\AC-DC\Highway To Hell\06 Shot Down in Flames.mp3
    D:\Music\AC-DC\Highway To Hell\07 Get It Hot.mp3
    D:\Music\AC-DC\Highway To Hell\08 If You Want Blood (You've Got It).mp3
    D:\Music\AC-DC\Highway To Hell\09 Love Hungry Man.mp3
    D:\Music\AC-DC\Highway To Hell\10 Night Prowler.mp3
    Obviously set the path to whatever it is in your system.....
    Hope that helps.
    I give full credit to Mitch, he helped me with this last year.
      Thanks, but the problem is creating the playlist directly from Riderunner.
      The path is correct, as you can see at the example.
      At the car is difficult to edit the playlist to remove the #EXTINF lines
      thanks and Regards
        hi,
        nobody have similar problems?
        thanks
          you dont have to remove #EXTINF lines
          -Thanks
          Mitch
          www.rush2112.net
          Sun, Come shine my way
          Wind, Carry me home
          The piece of me that died
          Will return To live again
            but the line with the #EXTINF at the medialist appears with:
            title: Acoustic Alchemy - Against The Grain - Against The Grain (and the correct title is Against The Grain)
            album: "blank"
            artist: "blank"
            and the other lines without the #extinf appears normal
            thanks
              ill have to think about this...
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                i also see no issue...
                i put a bunch of songs in playlist
                issue the command "savelist;e:\test.m3u8"
                issue the command "clearlist"
                issue the command "loadlist;e:\test.m3u8"
                and my media list looks same as before
                nothing is missing
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  you know, make sure you set in winamp....
                  this says, to RR, use RR for TAGS
                  prob should be removed from RR, to allow winamp to supply em
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    also i see you mention "DIRECTORY LISTS" that is not a playlist to me
                    that is a directory of files.....
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      I have that configuration in winamp.
                      I use a skin with directory list to create the playlist, then I load the playlist with the audio_player.skin wich use a medialist
                      thanks
                        well i have no issue.. so you know the rule
                        test with carwings...
                        it has a ML in the audio player skin, which btw, is a PLAYLIST list type
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          Hi,
                          I tried with carwings
                          I created a playlist with the audio_browser skin (to do that I changed a button, the home button to savelist, since there's no save list command in the skin)
                          I select that playlist with the audio_playlist skin and I have the same problem
                          thanks & regards
                            not for me, so... unless i can reproduce, i cant help ya...
                            i just use skintool...
                            savelist;c:\test.m3u8
                            clearlist
                            loadload;c:\test.m3u8
                            maybe attach your rr.ini
                            (remove any email/key)
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              we could do a teamviewer session too
                              pm me if you want to do that
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
