Winamp or Foobar2000
  • Winamp or Foobar2000
    Which is the best audio to use with RR ?
    I will be doing the usual media...songs, movies, DVD, CD...but have the system setup as 5.1 using 2 separate amps for front & rear.
    RR debug reports 5.1 channels but RR Carwings Lite with Winamp does not have separate front, rear, centre & sub volume controls in it like I saw in someone's audio skin for Foobar with the 18-band graphic.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
    Audio player+EQ is one thing and Audio mixer is another. Foobar has reputation for high quality audio but for most people with on board audio and average audio equipment (like me) any difference would be hard to distinguish - you should probably test it yourself. The EQ in Foobar has more bands than winamp, then the again 10 bands from winamp are enough for most people - you can use Foobar's 18 band EQ but you'd need to have a matching skin for it.
    Regarding the audio mixer (volume controls) if your windows mixer shows controls for Front/Rear/Center/Sub you can most definitely control those from within RR but again you may need to customize the skin to show the controls available to you. The standard skins likely only have 10 band EQs and the most common volume controls (Master/Wave/CD/etc).
    Ride Runner RR's Myspace
      Thanks Guino.
      Creating the extra controls on the skin is understandable but how do I find what these controls need to manipulate in Winamp so that I can give it a try?
        one thing is the foobar's DSP plugins... some really nice ones!
        im on foobar now... i really like it
        i set up the 31 band Eq, and output channel mixer, so i can "upmix" 2channel to 2.1channel and you could copy 2 channel to 4channel too
        very powerfull
        if there was a line in plugin, would make it rock!
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          I have build as screen for Foobar and Carwings. You can use it for helps !
          You can add these lines into your ExecTBL.ini file !
          Code:
          /*************************** Foobar2000 EQ Preset for when the skin restarts *************************************
          "PresetLoader","BYVAR;EQPreset;SetRock<<SetPop<<SetRap<<SetClassical<<SetJazz<<SetAcoustic<<SetVocal<<SetMovie<<SetPhone<<SetEq1<<SetEq2<<SetEq3||IFVAR;visuName=!ShpeckEmbedWndClass!;SETIND;!Avs;ON<<SETIND;!Avs;OFF"
          "SetRock","SETIND;!Rock;ON||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetPop","SETIND;!Rock;OFF||SETIND;!Pop;ON||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetRap","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;ON||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetClassical","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;ON||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetJazz","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;ON||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetAcoustic","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;ON||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetVocal","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;ON||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetMovie","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;ON||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetPhone","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;ON||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetEq1","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;ON||SETIND;!Eq2;OFF||SETIND;!Eq3;OFF"
          "SetEq2","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;ON||SETIND;!Eq3;OFF"
          "SetEq3","SETIND;!Rock;OFF||SETIND;!Pop;OFF||SETIND;!Rap;OFF||SETIND;!Classical;OFF||SETIND;!Jazz;OFF||SETIND;!Acoustic;OFF||SETIND;!Vocal;OFF||SETIND;!Movie;OFF||SETIND;!Phone;OFF||SETIND;!Eq1;OFF||SETIND;!Eq2;OFF||SETIND;!Eq3;ON"
          "AVSON","SETIND;!Avs;ON||SAVETOINI;visuName;!ShpeckEmbedWndClass!||SAVETOINI;RRFooVisuShpeck;AVS||SETVAR;visuName;!ShpeckEmbedWndClass!"
          "AVSOFF","SETIND;!Avs;OFF||SAVETOINI;visuName;FoobarVis||SETVAR;visuName;FoobarVis"
          Click image for larger version
            Many thanks pierrotm777
              Actually I'm using Foobar because of the higher output quality and DSP functionality, but there is still one issue remaining with large files >10min. Navigating using the slider and resume doesn't work. Checked already carwings skin and did a fresh allover install, switching to SSD and new motherboard.
              as a test you can use a long remix http://promodj.com/download/4066935/...odj.com%29.mp3
              Car: Volvo XC60
              CarPc: intel D945CLF2, 7"-Touchscreen, RoadRunner, IGo8
              HiFi: Diabolo D19/AndrianAudio A165g,2xPolk DB10, Signat RAMbo pimped, BRAX X2000
                HOW DO .... JRIVER MEDIA CENTER 18 ...TO WORK IN RIDERUNNER...THANKSS
                http://www.jriver.com/download.html SOFTWARE JRIVER
                THE BEST SOFTWARE... AUDIO PLAYER IN PC
