RideRunner Skin issue
  • RideRunner Skin issue
    I have the DFX plugin and it's a fresh install of both.
    No matter how much I clean out and make sure it's a fresh install (when doing stuff like updating RR because of a new version and getting nagged that it's out of date) I still get this problem.
    Here's the error message (and I will include a screen shot of it):
    "RideRunner screen loading error!
    While loading: menu1.skin
    menu1.skin not found."
    This happens when I tap on "Menu" to go between the 4 different menus within DFX.
    Any ideas?
    Here's a link to the screenshot:
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
    did you check for actual existince of that file?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Yeah, until I realized I didn't know where it was supposed to go when I didn't find it lol
      Why isn't the installer properly copying this file? I'm doing complete clean install, removing all traces even in hidden folders such as the /Application Data/ folder
      2.3L 4cyl Engine
      Current Build
      - M2-ATX 160W PSU
        Looks like there is a space between the the 1 after menu and the fullstop.
        either edit the filename of menu1.skin to menu1 .skin
        or where in the skin it's trying to call that feature
          Why am I having to do this though? lol
          It's literally a fresh install.
          Which file(s) reference the skin file?
          2.3L 4cyl Engine
          Current Build
          - M2-ATX 160W PSU
            depends if your plugin is installed in the same place as your RR
            your RR can be installed in normal or profile mode, this goes for the plugins as well, most plugins have one mode set on auto , riderunner installs in profile mode by default
            in normal mode all skin and plugin files are located in the RR folder on your c:\program files\riderunner, in profile mode all your skin and plugin files are installed in your documents\riderunner
            check if both plugin and riderunner are installed in the same mode
            View my worklog here
              also what exactly is a dfx plugin? to me its a skin...
              and it is responsible for that file
              prob best to post this in the DFX skin thread...
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                and btw, my dfx skin goes
                menu.skin
                menu2.skin
                menu3.skin
                menu4.skin
                the command to get to the next skin is "DFX_MainMenuNext"
                not sure where that is handled...
                could be in the exectbl, could be it the dfx support plugin (looks like in the dfx support plugin)
                which should be installed by the dfx installer...
                best to post all this in the dfx thread, where actuall users of the skin can help you
                you know my thoughts, test with carwings....
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  I did the standard install, also, I did this after removing ALL traces of RR from my system (including My Docs) so why am I having this issue?
                  Why am I having to troubleshoot where there's a skin file missing or to check if it's properly named?
                  I never chose which mode I wanted to install, there isn't even an option for that in the installer I used (2/1/2013) for DFX 5.1 and the latest RR.
                  Are you saying the issue is apart of DFX and not RR?
                  Sorry for the super late reply, been real busy lately with school and work and moving out to go to a different college, etc.
                  But yeah, I'll check out the DFX thread instead. Thanks guys.
                  2.3L 4cyl Engine
                  Current Build
                  - M2-ATX 160W PSU
