Weather not displaying symbol
  • Weather not displaying symbol
    The weather is not displaying symbol.
    What am I missing?
    Yes I checked with carwings
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
    The font you're using might not support the degree symbol. Change the font in DFX and see if it fixes it.
    Live mp3Car Facebook Chat
      there is a setting
      spoon feeding...
      -Thanks
      Mitch
      www.rush2112.net
      Sun, Come shine my way
      Wind, Carry me home
      The piece of me that died
      Will return To live again
        Originally posted by mitchjs View Post
        there is a setting
        spoon feeding...
        Tried that before it dont work I put the symbol in there but then it displays as in the pic.
        1.)Orion 2500d Amp
        1.)Orion 15" h2 Sub
        1.)Orion 8004 Amp
          Could it be a corrupt font file or that Western ISO-8859-1 is not being used?
          Otherwise if the extended ascii characters can be mapped:
          = 176(dec) 260(oct) B0(hex) 10110000(bin) (html).
          See also howeird's http://www.howeird.com/charmap.html (not that the GUI is html, but it's a ref I've used for ages).
          Sorry if this is way off. It's not my usual battery & electrical subject.
          It reminds me of why I use "R" instead of "Ω" - apart from its ease, it's confusing seeing 100Ω displayed as 100W.
            It could the way the text is displayed in the webpage.
            the text will be web compliant which means they stick &amp in there to allow extended characters to display correctly.
            May need to convert that in code when scraping the info.
              works for me...
              you know the rule...and if you dont, here it is.... Test in carwings...
              (also did you actually look at rr.ini?)
              Code:
              [Weather]
              WeatherDayNameLength=3
              WeatherUnits=USA
              WeatherDegrees=
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                What am I missing?
                I am having the same problem. Just started a few days ago. Nothing else changed - no change to fonts, etc. on the PC, no updates to RR or DFX skin, etc. Nada. I believe Enforcer must be right - there must have been a change to the data stream.
                Can someone who understands the raw data coming down take a look and do a compare with older data? There must be something that changed.
                I've tried all the tricks to fix the display to the degree symbol (), including editing the RR.ini, etc. (which should not be necessary to begin with given no other changes). It makes no difference. It is NOT a font problem! (at least that is not the core issue)
                  works for me...
                  OP did. See his posts above.
                    i just ran weather now... i see the the degree symbol... just fine
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Odd. I noticed some other odd behavior in my RR install (e.g. VOL +/- buttons click but nothing happens), so I am installing everything from scratch again (HD wipe, new OS, etc.), and see what happens. Perhaps installing a Plugin caused the issue. I'll try and figure it out if I can repro the problem.
                      Mitch, thanks for verifying it is probably NOT a data feed issue!
                        i wouldnt do install from scratch... seems too time consuming...
                        just disable all plugins (except weather)
                        there has been a change to the data feed for searching, i have made a tweak to the weather plugin, will be in Jan's 2013s' release
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          Mitch,
                          I did a fresh XP SP2 install anyway. I also installed the Jan 2013 RR version. The weather degree symbol worked fine the first few logins, but now it's exhibiting this strange text / error again. Here's what I can tell you:
                          1. I did not check the weather after installing each plugin (list below), but I can tell you it occurred either after installing a plugin or after some number of restarts of RR.
                          2. Here's the list of plugins I installed before I noticed the problem:
                          o GPSLockout
                          o InetRadioLabels
                          o MediaArt
                          o RRExtended
                          o RRFuelPrices
                          o RRMediaDB
                          o RRWebBrowser
                          o Weather (obviously!)
                          o DFX5 (ver. 5.1.2)
                          3. The problem now does NOT manifest itself with the CarWings Lite skin (it did before the new install). It ONLY occurs in the DFX 5.1.2 skin
                          4. I tried disabling all plugins except DFX 5 and Weather - same results.
                          5. Some of these plugins were installed with DFX 5. I used the most recent version of these plugins when I installed them. I checked the RRMediaDB and RRExtended plugin versions (which were installed by DFX), to be sure they were the most current (they were).
                          6. I happened to check the weather (and notice the bug) after installing an update to RRFuelPrices (via the updater tool in the corresponding Plugins folder). Not sure if that could be related or not.
                          Is there an easy way to cross post this discussion in the DFX 5 thread? If not, I'll re-post this info there.
                          Thanks for corresponding on this issue!
                          David
                            I can confirm somewhat the same problem. I did not reinstall Windows or anything, I did not install latest RR yet, still on 12-1-12. The plugins installed are DFXVoice, Mobilephone plugin and whatever the DFX skin puts in and or RR.
                            I disabled the DFXVoice & Mobilephone plugin.
                            I then loaded up carwings it was still messed up, I then exited RR, opened it back up, it was still messed up but somewhere along the way it finally started working again after a few restarts of RR and checking the weather in carwings. Then after a couple times checking weather (it was working) I went back to DFX and its messed up again n Carwings and DFX.
                            What I can tell you is sometime in 2012 it was working with all the same plugins so something recent is messing it up. I have to check but I don't think there has been an updat for DFX in the last few months at least.
                            1.)Orion 2500d Amp
                            1.)Orion 15" h2 Sub
                            1.)Orion 8004 Amp
                              I'm using the "a_bosanovacps"
                              for my font in DFX.
                              I was also getting a rectangle character
                              just next to the left of the degree sign.
                              So I deleted the equal sign in the DFX skin.ini file, and all is good now.
                              The degree only shows as it should now.
                              If this helps any.
                              Good luck.
