RR plugin written in C++
  • RR plugin written in C++
    Is it possible to write a RR plugin with the language C++ ?
    with the IDE Code::Blocks or Visual C++
    course it is...
    rr doesnt care what you code in...
    (ill be it, C++ much harder lang to code in, if you dont do it day to day)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Originally posted by mitchjs View Post
      course it is...
      If you have a little example RR plugin written in C++ that would be cool !
        i dont... sorry...
        you would have to learn about com object programming...
        its much much much much harder to do in C++....
        dont see the point...
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          RR is written in Visual Basic if I am not mistaken?
          Would be nice if it were rewritten in Visual Basic .net but that would require a full rewrite...
          Since it is written for a PC and won't run on anything else you might consider C# which is sort of a mixture of C++ and .net. No point in writing in C++ unless you are going to port it over to other computers since C# is MUCH more compact and much faster to write than C++.
          I believe RR should let you include just about any binary as a plugin so you should be fine?
            I know that !
            I write (very bad) already in VB.NET and C# but i should like learn the C++
              i agree with mitch, C++ is not for the faint of heart, not trying to say you wont be able to handle it, but is the hardest coding language to work with. unless you have plenty of time to learn it if not, avoid it. i have been reading about C++ for quite some time, and yet i go C# or vb.bet at the end. all i have done was add some stuff to activewinamp source and that was done most of it already. have a look to that it uses com object, so you can have a starting point there.
              BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
              RRTube ==> [View/Download Youtube Videos]
              WifiMan ==> [Wifi Manager]
              RRec ==> [Audio Capture]
              If You Want To Be Given Everything, Give Everything Up ...
              Bird York -- In The Deep --
                C++ actually is not any harder than any of the other languages. Realistically C# is MUCH more complicated to learn from my current experience. HOWEVER with C++ you will have to do most of the writing yourself where as the other languages simplify steps with routines or built in libraries that do it for you. C++ is the most universal language out there. You can write code for Windows PC's, Linux/WebOS/Android and many of the embedded OS's use C++ as their code base. I am unfamiliar with Mac/iOS but I am assuming they can also use C++ to write for them as well. It really boils down to the differences in the libraries supported by each different type of computer. Also, C/C++ is the model most of the common languages use to start out with. But as an example, you can use C# and some .net code and write a routine in like 3 lines that may take you 30 in C++.
                Rodney
