Help! Vista Mixer problems in Win7
  • Help! Vista Mixer problems in Win7
    Recently I've installed Win7 x32 on the car pc and got a problem with RR - it freezes when switching to audio skin (have tried carwings and dfx). After investigation, I've found, that if I remove "VistaMixerControl" folder, anything runs smoothly, but without volume control. I've tried to run "CoreAudio Mixer Control Explorer.exe" from this folder and it crashes immediately. After this, I try to run RR on my desktop (Win7 x64) - freezes in the same way, "CoreAudio Mixer Control Explorer.exe" also crashes.
    Have tried to re-install RR (01/2013 and 09/2012 versions) - same problems.
    Car pc has two audio cards - internal and ESI Juli@ (as default), desktop has one - Creative Audigy with KX drivers.
    What to do next?
    define crashes... apps usually except, and for good reason...
    for rr to work, this has to work: CoreAudio Mixer Control Explorer.exe
    prob related to default playback device...
    try to get the exception information posted... im sure its solveable
    but you might be the only one who can in the end solve it
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      that ESI card is one overkill card!!!
      musta cost a pretty penny
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        Thanks for answer, mitchjs.
        "Crash" is: "CoreAudio Mixer Control - Line Finder has stopped working" details:
        Code:
        Problem signature:
          Problem Event Name:	CLR20r3
          Problem Signature 01:	coreaudio mixer control explorer
          Problem Signature 02:	1.1.0.0
          Problem Signature 03:	4d513ad0
          Problem Signature 04:	mscorlib
          Problem Signature 05:	2.0.0.0
          Problem Signature 06:	503f01b1
          Problem Signature 07:	e2
          Problem Signature 08:	16
          Problem Signature 09:	System.ArgumentOutOfRange
          OS Version:	6.1.7601.2.1.0.256.1
          Locale ID:	1033
        That ESI card sounds very good - I've used it for a long time in the car (on XP system until now)
          yea, its an exception: System.ArgumentOutOfRange
          something in your system differnt than everyone else's
          prob easy to solve if i was on your machine debugging..
          i can build a debug.exe it might give a full stack dump
          but im guessing, im not getting any lines back from the windows mixer
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
