Level Meters
  • Level Meters
    Are there any skins with volume level meters for RR. I want to add level meters to my elite 2 main screen and would like to find a skin that has them to use to help me with my edit(I will just copy the level meter to my skin.....I want to add them to the spots circled in white).....thanks in advance
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
    At first I thought you were talking about VU meters which would require some serious Flash skills or Stereo Analog VU Meter - RMS - Version 1.51 winamp plug-inor maybe a stand-alone windows VU program.
    I have never seen volume level meters in RR, but the easiest way to do it would be to use a winamp visualization in the designated area. Searching Winamp, I found these:
    Peak v1.0 - Peak meter visualization plugin
    Osciloscope and VU meter - Osciloscope, VU Meter, spectrum analyser and spectrum meter
      The peak v1.0 is the type I'm looking for....thanks for the link. Now all i have to do is get it implemented into my skin properly. Will post screenshots of the results when finished, and will repost my updated skin file in case someone else might be interested in doing the same(once completed)!!!
      How do I install it is my next question. The visualization I'm using is from WMP....can this one run along with my current one, or do I have to use winamp exclusively to run this meter?
        i have a graphic eq visualication as avs for winamp.
        edit:
        here is a screenshot and in attachment the avs-file.
        you can change the color in avs-editor.
        Click image for larger version
Name:	AVS Graphik EQ.PNG
        RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
        RR-Plugin: IBusCommunicatoRR new Updates
          To give him what he really wants, I've been trying to turn that one sideways with only two bars (one for right and one for left), but I can't figure out how to get them to face each other and show the peaks.
          EDIT: This is almost there. So lets consider it a work in progress. Give this vis a try and let me know what you think, what should be changed, etc.
