xml settings files into C# plugin
  • xml settings files into C# plugin
    I try to convert a VB.net class into a C# class but i have an error !
    VB.NET class:
    Code:
    Option Strict Off
    Option Explicit On
    Imports System.IO
    Imports System.Xml
    Imports System.Xml.Serialization
    Imports System.Text
    Public Class cMySettings
        Public FTPUsername As String
        Public FTPPassword As String
        Public FTPHostname As String
        Public FTPHostpath As String
        Public FTPDirectorypath As String
        Private Shared XMLFilename As String
        Public Sub New()
            SetToDefault(Me)
        End Sub
        Public Sub New(FileName As String)
            XMLFilename = FileName
            If Path.GetExtension(XMLFilename).ToLower() <> "xml" Then XMLFilename = XMLFilename + ".xml"
            If File.Exists(XMLFilename) = False Then SerializeToXML(New cMySettings())
        End Sub
        Public Sub New(ByRef Settings As cMySettings)
            Me.FTPUsername = Settings.FTPUsername
            Me.FTPPassword = Settings.FTPPassword
            Me.FTPHostname = Settings.FTPHostname
            Me.FTPHostpath = Settings.FTPHostpath
            Me.FTPDirectorypath = Settings.FTPDirectorypath
        End Sub
        Public Shared Sub SerializeToXML(ByRef Settings As cMySettings)
            Dim xmlSerializer As New XmlSerializer(GetType(cMySettings))
            Using xmlTextWriter As New XmlTextWriter(XMLFilename, Encoding.UTF8)
                xmlTextWriter.Formatting = Formatting.Indented
                xmlSerializer.Serialize(xmlTextWriter, Settings)
                xmlTextWriter.Close()
            End Using
        End Sub
        Public Shared Sub DeseralizeFromXML(ByRef Settings As cMySettings)
            Dim fs As FileStream = Nothing
            ' do i have settings?
            If File.Exists(XMLFilename) = True Then
                Try
                    fs = New FileStream(XMLFilename, FileMode.Open, FileAccess.Read)
                    Settings = xmlSerializer.Deserialize(fs)
                Catch
                    'load error of some sort, or OBJECT deserialize error
                    'do we tell anyone?
                    Exit Sub
                Finally
                    If Not fs Is Nothing Then fs.Close()
                    fs = Nothing
                End Try
            End If
        End Sub
        Public Shared Sub Copy(ByRef SourceSettings As cMySettings, ByRef DestSettings As cMySettings)
            DestSettings.FTPUsername = SourceSettings.FTPUsername
            DestSettings.FTPPassword = SourceSettings.FTPPassword
            DestSettings.FTPHostname = SourceSettings.FTPHostname
            DestSettings.FTPHostpath = SourceSettings.FTPHostpath
            DestSettings.FTPDirectorypath = SourceSettings.FTPDirectorypath
        End Sub
        Public Shared Sub SetToDefault(ByRef Settings)
            Settings.FTPUsername = "FTPUsername"
            Settings.FTPPassword = "FTPPassword"
            Settings.FTPHostname = "FTPHostname"
            Settings.FTPHostpath = "Disque dur/Enregistrements/"
            Settings.FTPDirectorypath = "C:\temp\FTPCopy\"
        End Sub
        Public Shared Function Compare(ByRef Settings1 As cMySettings, ByRef Setting2 As cMySettings) As Boolean
            If Settings1.FTPUsername <> Setting2.FTPUsername Then Compare = False : Exit Function
            If Settings1.FTPPassword <> Setting2.FTPPassword Then Compare = False : Exit Function
            If Settings1.FTPHostname <> Setting2.FTPHostname Then Compare = False : Exit Function
            If Settings1.FTPHostpath <> Setting2.FTPHostpath Then Compare = False : Exit Function
            If Settings1.FTPDirectorypath <> Setting2.FTPDirectorypath Then Compare = False : Exit Function
            Compare = True
        End Function
    End Class
    C# class converted:
    Code:
    using System.IO;
    using System.Xml;
    using System.Xml.Serialization;
    using System.Text;
    public class cMySettings
    	public string FTPUsername;
    	public string FTPPassword;
    	public string FTPHostname;
    	public string FTPHostpath;
        	public string FTPDirectorypath;
    	private static string XMLFilename;
    	public cMySettings()
    		SetToDefault(ref this);
    	public cMySettings(string FileName)
    		XMLFilename = FileName;
    		if (Path.GetExtension(XMLFilename).ToLower() != "xml")
    			XMLFilename = XMLFilename + ".xml";
    		if (File.Exists(XMLFilename) == false)
    			SerializeToXML(ref new cMySettings());
            public cMySettings(ref cMySettings Settings)
    		this.FTPUsername = Settings.FTPUsername;
    		this.FTPPassword = Settings.FTPPassword;
    		this.FTPHostname = Settings.FTPHostname;
    		this.FTPHostpath = Settings.FTPHostpath;
    		this.FTPDirectorypath = Settings.FTPDirectorypath;
    	public static void SerializeToXML(ref cMySettings Settings)
    		XmlSerializer xmlSerializer = new XmlSerializer(typeof(cMySettings));
    		using (XmlTextWriter xmlTextWriter = new XmlTextWriter(XMLFilename, Encoding.UTF8)) {
    			xmlTextWriter.Formatting = Formatting.Indented;
    			xmlSerializer.Serialize(xmlTextWriter, Settings);
    			xmlTextWriter.Close();
    	public static void DeseralizeFromXML(ref cMySettings Settings)
    		FileStream fs = null;
    		// do i have settings?
    		if (File.Exists(XMLFilename) == true) {
    			try {
    				fs = new FileStream(XMLFilename, FileMode.Open, FileAccess.Read);
    				Settings = xmlSerializer.Deserialize(fs);
    			} catch {
    				//load error of some sort, or OBJECT deserialize error
    				//do we tell anyone?
    				return;
    			} finally {
    				if ((fs != null))
    					fs.Close();
    				fs = null;
    	public static void Copy(ref cMySettings SourceSettings, ref cMySettings DestSettings)
    		DestSettings.FTPUsername = SourceSettings.FTPUsername;
    		DestSettings.FTPPassword = SourceSettings.FTPPassword;
    		DestSettings.FTPHostname = SourceSettings.FTPHostname;
    		DestSettings.FTPHostpath = SourceSettings.FTPHostpath;
    		DestSettings.FTPDirectorypath = SourceSettings.FTPDirectorypath;
    	public static void SetToDefault(ref Settings)
    		Settings.FTPUsername = "FTPUsername";
    		Settings.FTPPassword = "FTPPassword";
    		Settings.FTPHostname = "FTPHostname";
    		Settings.FTPHostpath = "Disque dur/Enregistrements/";
    		Settings.FTPDirectorypath = "C:\\temp\\FTPCopy\\";
    	public static bool Compare(ref cMySettings Settings1, ref cMySettings Setting2)
    		bool functionReturnValue = false;
    		if (Settings1.FTPUsername != Setting2.FTPUsername){functionReturnValue = false;return functionReturnValue;}
    		if (Settings1.FTPPassword != Setting2.FTPPassword){functionReturnValue = false;return functionReturnValue;}
    		if (Settings1.FTPHostname != Setting2.FTPHostname){functionReturnValue = false;return functionReturnValue;}
    		if (Settings1.FTPHostpath != Setting2.FTPHostpath){functionReturnValue = false;return functionReturnValue;}
    		if (Settings1.FTPDirectorypath != Setting2.FTPDirectorypath){functionReturnValue = false;return functionReturnValue;}
    		functionReturnValue = true;
    The SetToDefault function return me an error !
    Where is my error please !
    What's the actual error you are getting? I thought you could only set static variables inside a static method, but I might be wrong...
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
      In french the error is 'Identificateur attendu'
        I have found my issue with the msdn help !!!
        the good translated class is :
        Code:
        using System.IO;
        using System.Xml;
        using System.Text;
                SetToDefault(this);
                    SerializeToXML(new cMySettings());
        	public cMySettings(cMySettings Settings)
        	public static void SerializeToXML(cMySettings Settings)
        	public static void DeseralizeFromXML(cMySettings Settings)
        			try {
                        XmlReader reader = XmlReader.Create(fs);
                        cMySettings i;
                        i = (cMySettings)xmlSerializer.Deserialize(reader);
        			} catch {
        				return;
        			} finally {
        				if ((fs != null))
        					fs.Close();
        				fs = null;
        	public static void Copy(cMySettings SourceSettings,cMySettings DestSettings)
            public static void SetToDefault(cMySettings Settings)
        	public static bool Compare(cMySettings Settings1,cMySettings Setting2)
        http://msdn.microsoft.com/fr-fr/libr.../d15aekdk.aspx
        and
        http://msdn.microsoft.com/fr-fr/libr.../he66c7f1.aspx
          I have always an issue with the deserialer function!
          I have tried:
          Code:
                      try
                          Settings = (cMySettings)xmlSerializer.Deserialize(fs);
                      catch
                          return;
                      finally
                          if ((fs != null))
                              fs.Close();
                          fs = null;
          and also:
          Code:
              public static void DeseralizeFromXML(cMySettings i)
                      try
                          //cMySettings i;
                      catch
                          return;
                      finally
                          if ((fs != null))
                              fs.Close();
                          fs = null;
          But when i try to read my variable , by example PluginSettings.COMPort , the variable is empty !
            Ok, If i convert the VB.NET code that follow , i obtain an error for the red line !!!
            Code:
                        Try
                        Catch
                            'do we tell anyone?
                            Exit Sub
                        Finally
                            fs = Nothing
                        End Try
                    End If
                End Sub
            In c# i obtain these lines:
            Code:
                        try
                        catch
                            return;
                        finally
                            if ((fs != null))
                                fs.Close();
                            fs = null;
            the error is 'can't convert the object in cMySettings
            Thanks for your help !!!
              not seeing this completely
              but in c# classes that you want to serialize should have a Serializable attribute
              [Serializable]
              then serial/deserial is easy!
              that code looks like my code
              anyway, there is tons of C# examples outside of this forum...
              attached is example
              hey I got some C# books, can you read English well enough?, id give you a book for free, just pay shipping
              good books.... ill get you more info... and titles
              (yea, real books, made of paper!)
              -Thanks
              Mitch
              www.rush2112.net
              Sun, Come shine my way
              Wind, Carry me home
              The piece of me that died
              Will return To live again
                Why not, Thanks !
                  micthjs, you are the best :-)
                  Into my Deserialize command , i have just added a 'ref' i don't know why and all is running well know so my code is :
                  Code:
                              try
                                  //cMySettings i;
                              catch
                                  return;
                              finally
                                  if ((fs != null))
                                      fs.Close();
                                  fs = null;
                  And i initialise the xml file like that:
                  Code:
                     DPath = pluginDataPath;
                              //Settings with Xml file
                              PluginSettings = new cMySettings(DPath + "iCarDuino");
                              // read in defaults
                              cMySettings.DeseralizeFromXML(ref PluginSettings);
                              // copy to temp
                              TempPluginSettings = new cMySettings(PluginSettings);
