2 Indicator Bugs
  • 2 Indicator Bugs
    i think there are two indicator bugs
    1.
    GPSVALID does not show the ON-Pic.
    configline in my skin is:
    I03,775,9,23,30,"GPSVALID",0,0,"Indicators\IND_GPS *.png"
    2.
    the OFF-Pic is shown behind the off layer. example, if i have ab transparent pic for OFF layer in the top off the skin-file, the off-pic is shown. by non transperant pic, it is not seen.
    configlines in my skin are:
    I,977,545,59,45,"!MYCANCEL"
    RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
    RR-Plugin: IBusCommunicatoRR new Updates
    use skintool, to verify "GPSVALID" indicator, make sure its goes TRUE
    as far as #2
    i dont follow, and would need a skin demoing it, just one screen will do, will all approiate graphics
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      - skintool say "true"
      - the filenames are in right format
      - if i use the indicator-code for "ONLINE", does it work fine.
      2.
      - look at the differences on pic no. 1 and 3 in zip file.
      - i have added some descriptions.
      - >>> IND_BUG.zip <<<
        for #1, i did a test with my own indicator, works fine...
        so if one indicator works so does another
        the drawing of the image isnt picky what indicator it is....
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          for #2 id need the files, not just screen shots...
          i have to be able to reproduce
          if you dont want to post them public, pm me
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            i did pm you
              1.
              2.
              Fir the GPSVALID:
              replace the 0 by nothing and IND_GPS* by INDGPS_* and create to png, INDGPS_00.png and INDGPS_01.png
              I03,775,9,23,30,"GPSVALID",,,"Indicators\INDGPS_*. png"
                i testet some different methods to get the GPSVALID hightlighted. no success
                now i will completly deinstall riderunner and reinstall it, after deleting all folders.
                  naw, thats crazy talk...
                  pierrotm, the file name can be "xxx*.png" doesnt need to have underscore
                  just as long as files are "ind00.png" and "ind01.png"
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Can you test into the SkinTool as Indicator if you have True as value when you turn on your GPS ?
                      See my second post.
                      yesterday i tested a long time.
                      there is a problem if running riderunner on virtualbox.
                      and there is a problem, if i don't use xport to split the serial gps port. then don't check RR that GPS is fixed.
                      edit:
                      i was in contact with mitchjs. most problems was resolved.
