command for popup
  • command for popup
    hello , the command for the menu popup close automatic only working in solid skin ? i try to put in transparent skin and dont working
    this command IDL,10
    thanks mikee
    well...
    thats an empty command
    IDL,10,"CANCEL"
    or
    IDL,10,"ESC"
    thats the proper use of the IDLE command, the deprecaited version is, "IDL,10" but then you need to have code in exctlb to process ONIDLE
    from history.txt
    + Screen Object Definition; IDLE - "IDL" additional option:
    ARGUMENT 2: is optional, this argument should be enclosed in quotes and is a command that will be executed
    when the idle time is exceeded. if this argument is not present, "ONIDLE" event is fired as usual.
    example: IDL,10,"CANCEL"
    This will execute "CANCEL" command after 10 seconds of IDLE.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      let me try
        WOWO ,work perfec with "CANCEL" perfect
        my friend , i find a scritp for the thermostat proyect what i talk to you , a find too a document with wifi module API , all command , how send you or post here ? thanks mikee
