when use RRCONFIG chinese cant display in any ini
  • when use RRCONFIG chinese cant display in any ini
    since i used 2013 0101 RR, if i run rrconfig chinese in ini cant display who can help me thanks
    need more information, rrconfig itself is a application requiring .net 3.5sp1 and Administrative rights
    (it will ask for elevation)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      chinese display
      when i changed RRCONFIG or direct to edit ini all chinese cant display in ini files its messy code
        I met the same issue with RR recent 2013 versions. The previous 2012 versions does not have this issue.
        My work around is to re-edit the Exectl.ini file with notepad manually, to correct the messy words with Chinese characters, then use "Save As...", select encoding as "Unicode" to save the ini file.
          if the file is Unicode to begin with, it should stay Unicode
          no changes to rrconifg, in a looong time...
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            It is really strange that the Exectl.ini will get messy with the Chinese characters once I run the RRconfig... Again, I did not have this issue when I use those 2012 versions RR.
              who knows... dam Unicode people
              start with a Unicode file
              im guessing, the file isn't Unicode
              most .ini files are ansi
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                I'm sorry for I made a mistake in my previous descriptions, which per my bad memory. I re-confirmed this issue on my CarPC this morning. Here is the correction:
                1. Once run RRConfig, the Chinese words in my RR skin will get messy. By checking the "Exectbl.ini" file under DFX4.0 skins folder, the Chinese words in this file were all changed to strange characters, and the encoding of this file was changed to UTF-8.
                2. I manually edit the Exectbl.ini file with notepad, type in Chinese words in the file, then "Save As" the file with "ANSI" encoding. Then RR skin will display Chinese words correctly. Saving as "Unicode" doesn't work.
                3. Whenever run RR Config, the Exectbl.ini file will get messy again.
                  you want to EDIT it, while in xxx
                  saving it as ANSI, will save Chinese, but that's because that is your local
                  which you can do, but then don't use RRCONFIG
                  you should be able to edit in UTF-8
                  worse case in UNICODE (UCS)
                  EDIT IN UNICODE
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    looks like it will revert to ansi
                    do this... STAY out of RRCONFIG!
                    edit the files as UNICODE (little endian)
                    RR supports, Unicode files for exectbl.ini
                    (not sure on skin.ini)
                    I got utf-8 on the mind from something else im working on
                    go with UNICODE
                    I don't think RRCONFIG will save back Unicode (yet)
                    so stay out of rrconfig.... but switch exectbl.ini to Unicode
                    and make sure RR is happy
                    confirmed: General.ini, Exectbl.ini both support UNICODE
                    SKIN.ini DOES NOT!!! (ill have to fix that at some point)
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      ok, use this rrconfig
                      test and let me know
                      it should maintain encodings now on rr.ini, skin.ini, exectbl.ini, general.ini
                      keep in mind, skin.ini isn't supported by RR in Unicode (YET)
                      m
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        i see a problem, since skin.ini isn't support in Unicode and SAVETOINI will loose encodings!
                        so.. keep skin.ini ANSI!
                        for now
                        good thing is rrconfig, shouldn't touch the encoding now...
                        hopefully all your Chinese stays intact
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          m
                          Hi mitchjs, I tried the new rrconfig but no success. Details as below:
                          1. After run the new rrconfig, all Chinese words were changed to question marks (???), instead of strange characters as the previous version rrconfig.
                          2. Manually edit Chinese characters in exectbl.ini file (in skin folder) with notepad, save as unicode, no Chinese showing on RR skin (it is blank there).
                          3. Manually edit exectbl.ini file and save as ANSI, RR skin showing Chinese correctly.
                            rr should support Unicode exectbl.ini (I say should, since my self never had one with Chinese chars in it)
                            rr config should NOT TOUCH the file encoding!!
                            I think that's correct on 1st run, since your file is ANSI, and rrconfig is Unicode based
                            you will see ??? but if you START as a Unicode file... it should be ok
                            like I said you can use ANSI, but it will only work for your region, ie, the file would be useless to me
                            if u save exectbl.ini as ansi, then use rrconfig v1.0.17, did the file change?
                            it still should be ansi
                            actually, it will be the DEFAULT CODEPAGE that's a better way to say it
                            best ATTACH Unicode version of your exectbl.ini file.... (rename as .txt)
                            best ATTACH ANSI version of your exectbl.ini file.... (rename as .txt)
                            it may be unrelated to file encoding, but how data is manipulated
                            I wont be able to read it, but I can do file compairs
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              thanks ,i will test tomorrow :) now midnight i must go to sleep
