Need help with vb.net and sliders !
  • Need help with vb.net and sliders !
    Hello all,
    I work on a very fun X10 automation around the ActiveHome API for RR and i need a slider that difine the dimmer from 0% to 100% .
    This is my code:
    Code:
        '* This Function will be called with requested slider code
        '* specified at the skin file. Simply return the value of the
        '* slider to be displayed. Values should range from 0 to 65536.
        '* It is also possible to intercept/change the slider code before
        '* it is processed in RideRunner (to overwrite existing codes).
        Public Function ReturnSlider(ByRef SLD As String) As Integer
            'This tells RR that the Slider was not processed in this plugin
            ReturnSlider = -1
            Select Case LCase(SLD)
                Case "x10_sld_e1" ' Shutdown Delay (MINUTES)
                    X10SliderE1 = SKININI.ReadString("X10SLIDERS", "E1", "")
                    ReturnSlider = Math.Round((X10SliderE1 / 10) * 65535)
                Case "x10_sld_e7" ' Shutdown Delay (MINUTES)
                    X10SliderE7 = SKININI.ReadString("X10SLIDERS", "E7", "")
                    ReturnSlider = Math.Round((X10SliderE7 / 10) * 65535)
            End Select
        End Function
        Public Sub SetSlider(ByRef SLD As String, ByRef Value As Integer, ByRef Direction As Boolean)
                    X10SliderE1 = Math.Round((Value * 10) / 65535)
                    If X10SliderE1 <> SKININI.ReadString("X10SLIDERS", "E1", "") Then SKININI.Write("X10SLIDERS", "E1", X10SliderE1)
                    ActiveHomeObj.SendAction("sendplc", "e1 dim " & X10SliderE1) 'x10sendplc;dim;c2;100
                    X10SliderE7 = Math.Round((Value * 10) / 65535)
                    If X10SliderE7 <> SKININI.ReadString("X10SLIDERS", "E7", "") Then SKININI.Write("X10SLIDERS", "E7", X10SliderE7)
                    ActiveHomeObj.SendAction("sendplc", "e7 dim " & X10SliderE7) 'x10sendplc;dim;c2;100
            End Select
        End Sub
    The slider run very well, but i obtain only a value from 0 to 10 and not 100.
    Where is my error please !
    Thanks for your help !
    Originally posted by Enforcer View Post
    Those sliders seem to be for shutdown timers in minutes not brightness.
    Unless by dimmer you mean slider.
    What we would need to know is the range 'value' can be
    It's not the RR dimmer that i change by this slider but the dimmer of a X10 CM15 module !
    I have found my error and replaced 10 by 100 !!!
