RR 04-01-2013 Release
  • RR 04-01-2013 Release
    SPRING? Could have fooled me...
    (ok today was nice (4/5/2013))
    Download HERE
    Not too much
    a bug, and a new RR Variable...
    HISTORY:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    3/21/2012
    # Fixed slider POINTER image scaling when scaling skins
    + Uservar; RRStatus. Values are, 1 = Stop, 2 = Play, 3 = Pause, 4 = Muted, 5 = UnMuted, 0 = Unknown
    3/8/2012
    + Added unicode support for skin.ini file
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Add the unicode option was a good initiative ! Thanks
      I cant seem to find the download link. Is it currently unavailable?
      Lexus SC300:
      Shuttle SB65G2/P4 2.4GHz/512 Meg RAM/120G Drive/Dynamix 706 TS/M4-ATX PSU/Rikaline 6010 GPS/RR/iGuidance 4
      Corvette:
      VIA EPIA SP-13000/512Meg RAM/250G drive/M1-ATX PSU/Xenarc 7" TS/BU-353 GPS/RR/iGuidance 4
        It's there - where it's always been.
        Got my copy...
        03 Hyundai Elantra GT {Worklog}
        HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
        RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
        cmdRR tall skin creator
        86 Pontiac Fiero SE 2m6
        possible carpc install
          Having an issue with this version. Updated RR and now it won't load skins. Tried Carwings and DFX5. Debug.txt below
          Code:
          04/30:
          20:39:01.938: Start -- Version: 4/1/2013
          20:39:01.938: OS Type: Windows 7
          20:39:01.938: FileManager: FileMode = Profile
          20:39:01.938: FileManager: mypath = C:\Program Files\RideRunner\
          20:39:01.938: FileManager: ProfilePath = C:\Users\AUDIO\Documents\RideRunner\
          20:39:02.016: Start Sequence: Starting Player...
          20:39:02.016: PLAYER: Initialization creating object
          20:39:02.016: Winamp AudPlayer---> Attempting start of winamp.exe
          20:39:02.078: Winamp AudPlayer---> waiting for window handle
          20:39:02.289: Winamp AudPlayer---> winamp.exe started: v20577
          20:39:02.289: PLAYER: Started
          20:39:02.289: PLAYER: Winamp Version: 5.61
          20:39:02.289: PLAYER: Initialization complete
          20:39:02.289: Start Sequence: Starting Radio Device...
          20:39:02.297: Start Sequence: Starting Serial Devices...
          20:39:02.297: Start Sequence: Starting Mixer...
          20:39:02.367: VMC---> Set object successful
          20:39:02.367: VMC---> SourceLine Count: 1
          20:39:02.375: VMC---> SOURCE: Mixer line #1: "Speakers"
          20:39:02.375: Start Sequence: Starting Speech...
          20:39:03.102: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
          20:39:03.148: INFO: LoadSkinVars() - Reading data from C:\Users\AUDIO\Documents\RideRunner\Skins\DFX5\skin.ini
          20:39:03.156: Plugin Manager: loading Global Plugins...
          20:39:03.164: Plugin Manager: Plugin Found: InetRadioLabels
          20:39:03.164: Plugin Manager: Plugin loaded (Global): InetRadioLabels
          20:39:03.172: Plugin Manager: Plugin Found: RRExtended
          20:39:03.172: Plugin Manager: Plugin loaded (Global): RRExtended
          20:39:04.453: Plugin Manager: Plugin Found: RRMediaDB
          20:39:04.453: Plugin Manager: Plugin loaded (Global): RRMediaDB
          20:39:04.586: Plugin Manager: Plugin Found: RRPandora(.NET)
          20:39:04.586: Plugin Manager: Plugin loaded (Global): RRPandora
          20:39:04.797: Plugin Manager: Plugin Found: SkinTool
          20:39:04.797: Plugin Manager: Plugin loaded (Global): SkinTool
          20:39:04.797: Plugin Manager: Plugin Found: Weather
          20:39:04.797: Plugin Manager: Plugin loaded (Global): Weather
          20:39:04.805: Plugin Manager: loading Global Plugins Completed.
          20:39:04.805: LoadSkin: C:\Users\AUDIO\Documents\RideRunner\Skins\DFX5\
          20:39:04.836: INFO: LoadSkinVars() - Reading data from C:\Users\AUDIO\Documents\RideRunner\Skins\DFX5\skin.ini
          20:39:04.844: Plugin Manager: loading SkinDir Plugins...
          20:39:04.844: Plugin Manager: Plugin Found: DFX5
          20:39:04.844: Plugin Manager: Plugin loaded (SkinDir): DFX5
          20:39:04.891: Plugin Manager: loading SkinDir Plugins Completed.
          20:39:04.891: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (menu_OFF.png)
          20:39:04.945: Global Hotkey: Successfully registered keycode:2112
          20:39:04.945: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (menu_On.png)
          20:39:04.953: ERROR: Loading image file(s) for: menu.skin (Invalid picture)
          20:39:04.953: Start Sequence: C:\Users\AUDIO\Documents\RideRunner\Skins\DFX5\ does not contain a valid skin!
          20:39:06.289: Shutdown: (1)
          20:39:06.289: Shutdown: (2)
          20:39:06.297: Shutdown: (3)
          20:39:06.297: Shutdown: (4)
          20:39:06.297: INFO: SaveResume() - Saving resume data to C:\Users\AUDIO\Documents\RideRunner\Cache\resume.ini
          20:39:06.297: INFO: LoadResume() - Reading resume data from C:\Users\AUDIO\Documents\RideRunner\Cache\resume.ini
          20:39:06.297: Plugin Manager: Warning Plugin inetradiolabels does not support Terminate Method
          20:39:06.297: Plugin Manager: Warning Plugin rrextended does not support Terminate Method
          20:39:06.297: Plugin Manager: Warning Plugin rrmediadb does not support Terminate Method
          20:39:06.375: Plugin Manager: Warning Plugin skintool does not support Terminate Method
          20:39:06.375: Plugin Manager: Warning Plugin weather does not support Terminate Method
          20:39:06.375: Plugin Manager: ALL Plugins unloaded.
          20:39:06.422: Shutdown: (5)
          20:39:06.422: Player is running
          20:39:06.422: Winamp AudPlayer---> Closing...
          20:39:06.422: COMReceive: RM_Exiting
          20:39:06.430: SDK command: RM_Exiting
          20:39:06.547: Winamp AudPlayer---> Closed
          20:39:06.547: Shutdown: (6)
          20:39:06.547: Shutdown: (7)
          20:39:06.547: OSUnloadMode: 1
          20:39:06.547: Global Hotkey: All keys unregistered
            You have fastmode=-1, so any skins with .png graphics wont work. Open RRConfig and on the first place set Screen Fast Mode to GDI+
            Code:
            04/30:
            Live mp3Car Facebook Chat
              + Skin command; "RRGetOption"
              + Skin Command; "RRSetOption"
              + Skin Command; "RRGetPath"
              + Skin Command; "RRGetFile"
              Please , what these commands do ?
              RR return me 'Command Not Executed: RRGetOption'
                Thanks.
