Is CMD DELAYEXEC with 0.5s possible?
  • Is CMD DELAYEXEC with 0.5s possible?
    i want to use the command DELAYEXEC with 0.5 seconds.
    Example: DELAYEXEC;0.5;CMDWHATEVER
    Is it possible to get this feature?
    i tried with 1 -> works; 2 -> works; 2.1 -> works too.
    but values smaller 2 with included dot, don't work.
    i'd like use Delayexec, because WAIT is bad. if WAIT is activ, RR don't accept any other commands at this time. and scrolling Labels are freezing during wait.
    RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
    RR-Plugin: IBusCommunicatoRR new Updates
    nope, looking at code
    If Val(dt(1)) >= 1 Then
    not sure exactly how the command works, ill see if .x is possible
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      ok, the timer runs at 1 sec
      so each number delays 1 sec
      so delayexec of 1 is 1 sec (prob turns out to be + .1)
      also any right of decimal point values would cause the command not to work at all
      due to a "bug" in the code (actually never expected anyone to use a decimal number)
      so
      DELAYEXEC;2.1;AUDIO
      would never run...
      that is easily fixed
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        does it mean, you will fix the code, and it is no longer possible to use decimals with dot?
          I will fix the code to drop anything decimal
          so 2.1 becomes 2, 3.5 becomes 3
          it never could of work in decimals, its running inside a 1 second timer
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            ok
            changing the timer isn't possible or to much effort?
              much effort...
              and not sure any real benefit
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                ok
