changing RR visualizations
  • changing RR visualizations
    i was wondering how do i change the visualization effect on RR, on RR config all i see is milk drop and avs. I want to put like a spectrum style analyzer...is this something i select in winamp or through RR config.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    there are some nice spectrum analyzers for AVS!
    that's what I use
    just set it up in winamp...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Mitch, I just tried it and it works for a few seconds and then it goes back to a black static window. Milk drop works.
      CarPc
      Project "Driver"
      Planning [99.9%]
        Btw Mitch , how in the world do I turn of that click sound in RR ?
        CarPc
        Project "Driver"
        Planning [99.9%]
          Clicksound:
          have a look in Exectbl.ini for "ONBTNPRESS"
          keep current avs selection:
          uncheck the box "randomly switch presets" in avs editor on winamp visualisation.
          Click image for larger version
Name:	avs editor.PNG
          RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
          RR-Plugin: IBusCommunicatoRR new Updates
            No onbtnpress found
            CarPc
            Project "Driver"
            Planning [99.9%]
              look to the skinpath. it exist.
                sure does...
                the click comes with the skin, so its the exectbl.ini inside the skin...
                you can edit that with rrconfig...
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  I looked in the exectbl in RR, I deleted a few things that match..doesn't stop the sound. Is there a line of code I have to add??
                  CarPc
                  Project "Driver"
                  Planning [99.9%]
                    read our answers again.
                    and then browse to skinpath, not to RRpath. and open there the exectbl.ini
                    btw: you can disable commandlines if you add a "/" before itself. deleting is not needed.
                      I got it... thanks fellas
                      Mitch, i cant get AVS to work. its unstable. it crashes winamp when I run it by itself and when i run RR it crashes RR. is it a video card problem?im just using the built in video card on my intel D510mo board. Milk drop is the only one that work...
                      CarPc
                      Project "Driver"
                      Planning [99.9%]
                        After searching the web, it seems it has something to
                        Do with the avs plugin itself.
                        CarPc
                        Project "Driver"
                        Planning [99.9%]
