Pandora problem??????
  • Pandora problem??????
    when RR loads up....i get a message saying no credentials found for pandora....how do i fix????
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
    Enter your Pandora credentials? lol
    -Start RR in carwings (to be sure needed skins are there)
    -Go to Plugin Manager
    -Click RRPandora in the list
    -Click Settings
    -Enter username/password on the settings screen.
    -Save
    If that doesn't fix the issue its very possible Pandora changed their code again and the plugin is buggered so deactivate it (move it out of the plugins folder)
    Live mp3Car Facebook Chat
      -Click Settings
      -Save
      did what u said....now i can create stations...but nothing seems to be playing...how do i fix????
        Do you have winamp installed? What version? The plugin requires winamp to play audio. Are the stations you created showing up in the list on rrpandora screen?
          i use wmp....but i'm installing winamp just for pandora.......just need to figure out how to set it up
            winamp shouldn't require much configuration to get rrpandora to work. Just install and you should see a winamp instance start when RR starts. The code that controls winamp is a .dll that Mitch created for his webradio app.
