2 Issues with a fresh instal of RR
  • 2 Issues with a fresh instal of RR
    I just installed the newest version of riderunner. I am using a modified BMV skin. I have everything working except two things...
    1. I have the gps working fine. I use i guidance for navigation. I have speed, altitude, lat and longitude displayed on the skin and working fine. On the main screen, I have an area that shows the current city and zip code from the gps. Before updating RR, this worked great. I placed the zips.dat into the new RR folder. Does it need to go somewhere else? Am I forgetting something?
    2. Previously working with the older version was the indicators. However, after installing the newst version, I can't get them to work. I have the indicator folder in my skin folder as before. I placed a copy in the riderunner folder as well. I installed the GPSIndFix and that didn't help. With the old RR, I needed to add GPSIndFolder=Indicators and GpsIndFix_Enabled=true into the rr.ini to make it work. I can't find a rr.ini in this new version.
    Any help with these would be greatly appreciated.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    RR doesn't use zips.dat at all, there is a plugin, called GPS 2 City.... https://dl.dropboxusercontent.com/u/....1%20Setup.exe
    I have no idea what gpsindfix is... I surmise its not needed... but you might have a plugin corrupting indicators...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Thanks Mitch. That worked. I forgot to reinstall the gps2city.
      The gpsindfix was needed on the older version to get these indicators working. Also, the old rr had a rr.ini file. I can't seem to find this in the new version... Anyway, you would add GPSIndFolder=Indicators to show the folder of indicator images and GpsIndFix_Enabled=true into the rr.ini.
      Since I can't find the rr.ini file, I can't add these lines. Any idea's where this file is located now?
        You should find rr.ini in My Documents..
        i.e. this is my path to the RR config files..
        C:\Documents and Settings\davekra\My Documents\RideRunner\Config
          Thanks for your help. I will check my doc after work.
          This morning on my way to work I noticed that the city didn't change automaticaly as I drove around. If I clicked on the area where I placed the city and zip on my skin, it did update to the current city. However, as I drove, it changed to another town 20 miles away... Something is goofy with it.
            I decided to investigate the incorrect city showing up. I looked into the gps2city folder and found the zips.dat file. It was about half the size of the one I previously was using. I made a copy of the original gps2city zips.dat file and added my previously used zips.dat file to the gps2city folder. When I restarted rr, the correct city showed. I'll keep testing it for a few days to make sure that was the problem.
            Now to figure out how to get these indicators working...
              Now that I found the rr.ini, I got the indicators working by adding the lines: GPSIndFolder=Indicators and GpsIndFix_Enabled=true. Now I am getting a popup, GPSIndFix Run-time error '13': Type mismatch, every time rr starts. I am guessing the GPSIndFix is not compatible with the new version of rr. I uninstalled it and the indicators stopped working. I then reinstalled it and, after getting the popup, they worked again.
              Is there a newer version of the GPSIndFix available or some way to remove that popup?
              Click image for larger version
                I don't know anything about that gps fix, never heard of it till now
                and why do you even need it?
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  GPSFix is used with blue ZX3's indicators. I used it for years with my old version of rr without issue. Now with the updated version, I am getting the pop up. The indicators don't seem to work at all unless I use the fix and GpsIndFix_Enabled=true in the rr.ini file.
                    what indicators don't work?
                    I don't know of any blue ZX3's Indicators....
                    my advice would don't use the GPSFix, and solve the actual problem
                    nothing is known to me about indicators that don't work...
                    a plugin can destroy an indicator (bad programming, or even intentional)
                    course I have no idea what you got in your system, you could ATTACH a debug.txt
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      here is some info for you....
                      fix your skin!!
                      01/21/2012
                      * Skin Indicator; "heading" changed to "RRGPSHeading"
                      + Skin Label; "RRGPSHeading" shows "N", "NE", "E", "SE", "S", "SW", "W", "NW"
                      RRGPSHeading indicator has a path to file
                      for example
                      so... go to you skin, and find all "HEADING2" and change to "RRGPSHeading"
                      and put all the images in the skinpath....
                      with the right naming N.jpg, NE.jpg...etc
                      oh and NA.jpg too
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        GpsIndFix is now a part of the Bluezx3's RRExtended plugin , so you need to install this very cool plugin !
                        = GpsIndFix Sect =
                        Description
                        Allows usage of additional GPS heading Indicator images to show both dir & Sat count all in one indicator
                        The ind will indicate the Signal strength by changing the ind color by the number of satellites,
                        meaning...weak(1-4), fair(5-6), good(7+)
                        Ini Settings
                        (rr.ini or skin.ini)
                        GPSIndFolder=xxxx -(optional) Specifies a folderName inside a skin's folder that will be used for the indicator images,
                        if not specified, will use the 'Heading Inds' folder in the plugin's folder for the images
                        GPSIndFix_Enabled=(True/False) -Enables or disables this feature
                        Commands
                        None
                        Labels
                        None
                        Indicators
                        "HEADING2" -Name of indicator to show the GPS DIR &/or Signal Strength
                        Addition Notes
                        Accepts either jpg or png file extions, it will use whichever extention is on the N.xxx/N_1.xxx ind graphi
                        ****How to use the indicator*****
                        To use the signal strength you must have the additional indicator graphics. These new
                        graphic indicator file names are the direction(N,NE,E,SE,S,SW,W,NW) followed by a _x.(jpg/png),
                        where x is 1-3 using the above as the guide lines. So "N_1.png" would be north with a weak signal
                        where as "SE_3.png" would be southeast with a good satellite signal.
                        Sample indicators are included in the 'Heading Ind' folder (iG style)
