notepad sendkey
  • notepad sendkey
    hi , i have a notepad what i put the comands for pg down and pgup , working fine , but when i click the button down or up , the notepad gone and then come back , how i can fix that ? for what dont happend this
    the commands what i use in exectbl are
    "DOWN","ACTIVATE;NOTEPAD||SENDKEY;{PGDN}"
    "UP","ACTIVATE;NOTEPAD||SENDKEY;{PGUP}"
    thanks
    See the History files into the RR documentation:
    12/14/2011
    + New option "OPT_NOFOCUS" for Screen Object Definition "AX", this will cause the embedded window
    to keep its focus even when RR skin is clicked on (no flashing of embedded window)
    ex. AX,0,0,800,450,"OPT_NOFOCUS"
    this will embed the window at (0,0) 800 wide, 450 tall, with the NO_FOCUS option.
    + New option "OPT_BACKCOLOR#RRGGBB" for Screen Object Definition "AX", this will cause the embedded window
    background color to be set. (in most cases this is not needed)
    ex. AX,0,0,800,450,"OPT_BACKCOLOR#000000"
    this will embedd the window at (0,0) 800 wide, 450 tall, with the Black Background
    + Screen Object Definition; AX, eXtended Application embed area define
    ex. AX,0,0,800,450, "optionlist"
    options;
    OPT_NOTOUCH - do not remove window boarders
    OPT_NOFOCUS - do not lose focus on application when RR screen elements are clicked.
    OPT_BACKCOLOR#RRGGBB - set background window color to RRGGBB.
    OPT_PARENT - embedded window parent window set to RR. (advanced)
    OPT_ATTACHINPUT - sets the embedded windows input processing to RR's. (advanced)
    ex. AX,0,0,800,450,"OPT_NOTOUCH,OPT_NOFOCUS"
    The AX fence replace the old A fence !
      hi my friend , i have that option
      AX,10,64,700,534,"OPT_NOFOCUS"
