Audio file extensions in RR
  • Audio file extensions in RR
    Hello everyone, I would like to be able to read the file extensions (.wav, .mp3 . ape ecc ecc) that I'm listening to audio in RR.
    is it possible?
    how could I do?
    greetings
    carlo
    possible that no one can help me? ; (
      Patience carlo201983 It's a holiday weekend in North America. Someone will help.. SNO
        Use the RRConfig program and into the Music settings , use the button (in the bottom) 'Select'
        or manually:
        Edit your rr.ini file and edit the lines that follow:
        [Audio Player - Paths]
        MusicPath=C:\Users\pierre\Music\Mp3\
        RRMusicBrowse=True
        PlaylistPath=C:\Program Files\Ride Runner\PlayList
        AudioFiles=.aac,.m3u,.m3u8,.mp3,.wav,.wma,.xm,.xmz,.ac3
          From another thread
          Originally posted by bratnetwork View Post
          check in rrconfig.exe under the Music > Page 1 tab. At the bottom right it has a box for "Audio File Type". make sure you have .mp3 in there along with any other type you want to play, and also playlist types.
            I know that we are not understanding. I would like to see the file type is being played at that time. understand?
              Carlo,
              is this what you are seeking?
                hello I have enabled "Show extension" extensions but not viewing them.
                I am attaching a picture under my skin.
                for example I would like to create me a space underneath where is "Track, genre, bitrate" by entering the file type. I would like them if I'm listening to a WMA WMA just has to go out, if I am listening MP3 to appear MP3, and so on.
                To understand this better see figure below.
                Click image for larger version
                  Don't think that is currently possible.
                  Would need a change in RR source to expose that value.
                  Or maybe a plugin, but the source would be best.
                  Shouldn't be too difficult, send a PM to mitchjs
                    already contacted him to mitchj but he replied that he could not remember : ( I'm desperate
                      maybe its not directly in RR...ill add
                      "RRTrackExt" label tonight, for the sept 2013 release
                      ill return the lthe extension of the file name, for audio and video
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Sun, Come shine my way
                      Wind, Carry me home
                      The piece of me that died
                      Will return To live again
                        so I look ? I did not understand if Rr will be available in September or if there will be a plugin.
                        Thank you
                          just when i thought nothing new left to be added in RR..
                          Carlo201983, wait a few days, the feature you asked will be added to RR
                            yes, me too, felt good to work on the old lady!
                            its in 9/1 build, trying to get it updated on NISU site...
                            m
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              Sorry to quickly hijack the thread but to play MP3's, should they just play normally after RR is installed or do I need to install WinAMP ? I think I remember reading somewhere that WinAMP was needed (and maybe older versions only) ???
