RUNQ problem
  • RUNQ problem
    I have been out of the game for a while... at least a year, but I just installed the newest RR.
    I'm having an issue with RUNQ command.
    I want to copy the contents of one directory to another. Here is my command.
    RUNQ;cmd.exe|/C COPY "$skinpath$THEME\$THEMECOLOR$\SCREENS" "$skinpath$"
    I can manually run this in the windows run utility and it works. Here is what I use in the windows utility.
    CMD.EXE /C COPY "C:\USERS\x\DOCUMENTS\RIDERUNNER\SKINS\ELITE 2\THEME\GREEN\SCREENS" "C:\USERS\x\DOCUMENTS\RIDERUNNER\SKINS\ELITE 2\"
    RR will execute the command, but the files are not copied. The variables are showing correctly according to the skin tool. Anybody have any ideas why? I know this used to work.
    Thanks!
    I found the problem. I believe when Windows 8 was released, the cmd was updated and must be they changed something in Windows 7 as well.
    Instead of using RUNQ;cmd.exe...
    I changed it to RUNQ;C:\Windows\System32\cmd.exe...
    Now I just need to check the skin for other cmd.exe commands!
