Problem Media player classic home cinema MPC-HC
  • Problem Media player classic home cinema MPC-HC
    Good evening I have a problem with mpc -hc pratically rr minutes and the song may not function properly. There are no special settings to be made differently from those who use the old obsolete mplayer ?
    Tkyou
    Carlo
    hu?
    song?
    media player classic HC is for video playing
    and what does "pratically rr minutes and the song may not function properly" mean?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      with virtually Mpc hc the minutes elapsed and time remaining are incorrect. over the bar videopos that does not work. I wondered why I old mediaplayer with these problems were not there but with the home cinema .. Mitch you know something ?
        what is the use of THE WORD "virtually" here?
        I still don't follow, MPC HC has nothing TO DO THE THE old Media player classic
        (not as far as RR concerned)
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          maybe do it before to post the screen of the problem. . What I can say is that while being integrated with RR malfunctioning . has problems.
            hello mitchjs,
            here's the problem I told you about.
            reading the time is incorrect. look at the red circles.
            the progress bar works as heavenly. but with MPC HC does not work.
            I was wondering if there were any for MPC HC special settings to do in the skin.
            screen MEDIA PLAYER CLASSIC
            Click image for larger version
            screen MEDIA PLAYER CLASSIC HOME CINEMA (problem)
            thanks look forward to hearing from you
            greetings
            CARLO
              maybe its MPC HC, that version, maybe the media file
              im running v1.7.0.7751
              also... since that info isn't in car wings dynamic light, i have no idea where you are getting that information from
              I assume its a label, post the label that you feel is in error
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                the version of MPC HC I use is the latest available: 1.6.8
                I use the label are ("CURRENTTRACKTIME" "TrackTime")
                which then are those who work with the old mediaplayer.
                by the way, because I am. there is the possibility of starting riderunner you can decide which programs start at the same time?
                  I don't see anything wrong with the two labels
                  try other video files...
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    repeat. with the old mediaplayer (integrated) in rr, both tracktime he currenttracktime are correct while MEDIAPLAYER CLASSIC HOME CINEMA .. are completely busted. will be a BUG too. tried with different video files but the behavior is always the same.
                      oh well what can I tell you, use the OLD OLD, out dated media player classic(and doesn't play much, and has many other issues)
                      myself and the rest of the people will use MPC-HC and move on in life
                      just because you cant get it to work, doesn't make it a bug, as I showed it works fine for me
                      and I bet others too
                      got some basic rules here; #1 use skintool, #2 test with carwings
                      only thing I trust for testing labels and such is skintool
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        the thing that I'm sorry and that I write but do not believe me.
                        I also did the test with the CARWINGS and skin tool (like you did) .. same problem .. durations busted
                        so it's obviously a bug.
                        you want to see another screen?
                        I'm sorry but unfortunately drilo RR suffers from several BUG.
                          you can edit carwings skin to have the labels, open "video_player.skin"
                          and add
                          Code:
                          L,200,54,120,30,255,255,255,12,"Arial:B","CURRENTTRACKTIME","",""
                          L,400,54,120,30,255,255,255,12,"Arial:B","TRACKTIME","",""
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            like I said, there is no known, bug just because you say it is
                            if I can reproduce, then its possible its a bug, I cannot, it just works
                            one thing, if it didn't work, the video slider wouldn't be able to work
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              you still do not believe me.
                              here is the data of CARWINGS with MPC HC
                              here is the data of CARWINGS with OLD MPC (rr integrated)
                              how can REVISE .. with the old MPC (the integrated RR) detects everything correctly, while the version with MPC HC is all busted.
                              DO YOU BELIEVE ME NOW?
