RR 09-01-2013 Release
  • RR 09-01-2013 Release
    Back to School folks!
    Download HERE
    couple really little things in this release
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    9/3/2013
    + Skin Label "RRTRACKEXT" displays current track (audio/video) file name extension in upper case.
    8/9/2013
    # Fixed Incorrect math in SetTrackPosition for Foobar2k Player
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thank you Mitch! Peace & Rush be with you!
      Thanks for this new release mitchjs
        Thanks mitch! We appreciate all the hard work!
          embededd program does not work.
          add name program to start but when you start the application process selected RR will not start.
          you are aware of this BUG?
            im going to play dumb here, but how are you starting the application
            off the top of my head, there is no feature to start an application when rr starts
            (but I don't use rr enough daily to remember all its 100s of features)
            you can of course do it, with some skincode
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              I know how to do it, I'd say thank you.
                mitchjs,
                Is possible to a an option to the IDL screen function ?
                As that exist for the TMR feature, i should like to have an command when the IDL value is done !
                ex:
                IDL,5,"MYCOMMAND"
                Thanks !
                  that should be there, read history... like I said I cant remember all the stuff rr does
                  im too old!
                  the who idea is to use less, exectbl.ini
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Originally posted by pierrotm777 View Post
                    mitchjs,
                    ex:
                    IDL,5,"MYCOMMAND"
                    Thanks !
                    This is from History
                    2/21/2011
                    + Screen Object Definition; IDLE - "IDL" additional option:
                    ARGUMENT 2: is optional, this argument should be enclosed in quotes and is a command that will be executed
                    when the idle time is exceeded. if this argument is not present, "ONIDLE" event is fired as usual.
                    example: IDL,10,"CANCEL"
                    This will execute "CANCEL" command after 10 seconds of IDLE.
                    + Screen Object Definition; TIMER - "TMR" additional option:
                    when the timer expires. If this argument is not present, "ONTIMER" event is fired as usual.
                    example: TMR,5,"PlaySound;$SKINPATH$Sounds\Click.wav"
                    This will play the click.wav sound every 5 seconds.
                      Any one else having huge hassles with the site trying to log in and download the new version? I have to log in twice for it to work and then it keeps taking me to the online store home page. I try to select software and it asks me to log in again and keeps going in this endless loop??
                      I can't contact them either as the website online contact form refuses to recognise my postcode???
                        there is a FAQ on this, its cookie related...
                        now im not sure about the postcode thing
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          im too old!
                          Hoops ! Sorry !
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              yes, this function exist:
                              example of my exectbl.ini
                              Code:
                              [Idle Function]
                              "ONIDLE","RUNQ;$SKINPATH$Scripte\reg-explorer.cmd||QUIT",exit_rbwin.skin
                              in exit_rbwin.skin
                              Code:
                              IDL,7
                              RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
                              RR-Plugin: IBusCommunicatoRR new Updates
