C# (or any .Net language) example using a custom list (CL)
  • C# (or any .Net language) example using a custom list (CL)
    I have a skin with the following definition:
    Code:
    /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
    IL,CL,transparent.bmp,sel.bmp,end.bmp,0,50,60
    /, S, x, y, w, h, fore R;RGB, G, B,  back R;RGB, G, B,  folder R;RGB, G, B,  file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
    SC,158,208,474,236,255,255,255,3,80,40,0,0,0,255,128,0,TRUE,20,"Lucida Sans Unicode"
    I'm having trouble figuring out how, in C#, to get each line into the list with an icon at the beginning of each line.
    Does anyone have a C# example (or any .Net language or even VB6) of how to load the list and then how to determine which item was selected by the user?
    Regards,
    Jim
    try to contact the user pierrotm777
    RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
    RR-Plugin: IBusCommunicatoRR new Updates
      Code:
                      case "rr_translator_fromtolanguage":
                          SDK.Execute("MENU;RRTranslator_Languages.skin||CLCLEAR;ALL");
                          if (File.Exists(DPath + "Languages.txt")) {
                              string[]  sArray = File.ReadAllLines(DPath + "Languages.txt");
                              for (int p = 0; p <= sArray.GetUpperBound(0); p++)
                                  SDK.Execute("CLADD;" + sArray[p]);
                                  if (File.Exists(DPath + "Languages\\" + sArray[p] + "\\" + sArray[p] + ".gif"))
                                      SDK.Execute("CLSETIMG;" + (p + 1) + ";" + DPath + "Languages\\" + sArray[p] + "\\" + sArray[p] + ".gif");
                                  else
                                      SDK.Execute("CLSETIMG;" + (p + 1) + ";" + DPath + "Languages\\Error.gif");
                              //selectionne la ligne du language actuel
                              SDK.Execute("CLFIND;" + INI.ReadString("RRTranslator", "Language", ""));
      	                                        } else {
                              SDK.ErrScrn("!! Info !!", DPath  + "Languages.txt file is not found !!!", "");
                          result = ProcessCommandResults.CommandProcessedStayOnScreen;
                          break;
