Carwings lite - not muting winamp when DVD is started ?
  • Carwings lite - not muting winamp when DVD is started ?
    I am a newbie working with riderunner and working out how it all goes together. I am getting there and will have several questions about coding and where stuff is located but my first question is about the current buld with Carwings that comes with it. It appears that there is a missing event command to mute Winamp when loading a DVD. What should I add where ?
    jim
    why would we want to mute winamp?
    what does winamp and "loading a dvd" have any connection?
    if you have your winamp, set to PLAY dvds, disable that!
    rip winamp too
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      If I am playing music and I load a DVD, the music does not stop when the DVD starts and sound from both comes through the system
        Using MPC-HT for video and DVD player
          it should pause..
          and not because you "load a dvd"
          but because you go to the VIDEO or DVD player
          if you want it to pause when you "load a dvd" some event has to happen
          then on that event, you would switch to "DVD"
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            OK --- the event for recognizing that a DVD has been put in the drive is already somewhere in the events coding, as when I do that, it automatically switches to the DVD player within RR. I need to look for that event and then also add another similar event to pause winamp ?
              no...
              sounds like its switching to DVD wrong!
              as if it was correct, winamp would be paused
              carwings as a base doesn't have the event to auto switch...
              maybe its in the global exectbl.ini
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
