Label MEM incorrect
  • Label MEM incorrect
    does anyone know explain to me why the label MEM does not correctly detect the actual use of the PC's memory?
    Alright guys since no one answers and this RR is full of bugs step in Centrafuse.
      In my Vista 32 bits , the label 'MEM' return me '36%'. How do you use it (send your .skin file !!!)
      I hope that Centrifuge give you what you need (freely :-) )
        In win7 is win 8 don't function.
          May be mitchjs can see that ?
            I can just public string label of the MEM. I have an actual consumption of 20% rr but says that I am consuming 77%. because it is a misreading?
              MEM shows you the Value of FREE Memory in Percent,
              ALLMEM shows you the Value of Memory you have in your PC in MB
              FREEMEM shows you the Value of FREE Memory in MB
              take a look with a running stream also and you see that the value of MEM and FREEMEM will be smaller
                finally a person who explained everything well. so it all adds up. I'll just do a test in front of the pc. thank you very much
                  carlo , but that all info you find in RR documentation , skin commands
                  "CPU" - Shows CPU Load % (Ride Runner Only)
                  "MEM" - Shows Total Memory usage % (Ride Runner Only)
                  "FREEMEM" - Shows Physical Memory available (Kb can be used as format, otherwise it is in Mb)
                  "ALLMEM" - Shows Total Physical Memory (Kb can be used as format, otherwise it is in Mb)
                  "PAGEMEM" - Shows Page Memory available (Kb can be used as format, otherwise it is in Mb)
                  "PAGESIZE" - Shows Page Memory Size (Kb can be used as format, otherwise it is in Mb)
                  "ALLFREEMEM" - Shows All Memory available (Kb can be used as format, otherwise it is in Mb)
                  "TOTALMEM" - Shows Total Memory size (Kb can be used as format, otherwise it is in Mb)
                    when reading documentation to me "MEM" should show used... not free %, but I changed documentation "MEM" is free %
                    I added "RRMemoryUsed%" which is used %
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Sun, Come shine my way
                    Wind, Carry me home
                    The piece of me that died
                    Will return To live again
                      "RRMemUsed%" in the September RR does not work.
                      I do not display anything.
                        is more ease ask , that dont search
                        I'm interested to know the memory used in PERCENT "%" and not free memory.
                          i know, and its there now, in next release !!!!!
                          officially as "RRMemUsed%"
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            Okkk mitchjs.
                            Thank you
                              now works even if it is not perfectly aligned with the actual consumption.
                              But I would not want to depend on the fact that I'm trying this new release on a virtual machine.
                              Meanwhile, thank you very much. as always the best
                              hello
                              carlo
