RR 01/01/2014 Release
  • RR 01/01/2014 Release
    Happy New Year!
    Download HERE
    HISTORY:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    12/22/2013
    # Fixed "Visu" indicator to use literals "True" and "False" so that its not locale affected
    12/15/2013
    ^ Documentation fix; skincommands.txt
    "MEM"			- Shows Total Memory free %
    + NEW Skin Label; "RRMemUsed%" Shows Total Memory used %
    * Player FooBar2k Control Server, now gets Bitrate live vs from file, so VBR is shown
    11/24/2013
    # When not using ID3 Tags, fix for "TRACKNAME" which will now have something (based on titles after or filename)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thank you, Mitch...and happy New Year!
      What prompted the change to TRACKNAME? It was working fine just the way it was (I do use ID3, but I'm concerned about Internet radio and FM/XM which don't use ID3)
        someone found a bug it in.... and it was a legit bug, it was empty I think...
        doesn't have anything to do with FM or Xm/Sirius... just music
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Can I get a pre-release copy for testing?
            you know where the daily builds are...
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              I forgot. PM me.
              EDIT: got it, it's all good, thanks for all yo do Mitch.
                I have an issue into the audio_player.skin with the ML list that don't run because the files transparent.bmp, sel.bmp and end.bmp doesn't exist into the default skin !!!
                Can you add them into the last version ?
                  I have no idea what you are talking about...
                  but, those files do come with "carwings dyanamic lite" and are installed by the installer
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Ok, i think that my issue when i uninstall a plugin where these file exist (shared files issue)
                      I have a little issue with the directory list (SD):
                      I use these lines :[List]
                      SD,00,00,-1,-1,"$RRGMAILPATHFILE$","*.*",True
                      S,35,57,534,163,255,255,255,255,255,255,064,064,06 4,255,128,000,TRUE,18,"Arial:B"
                      IL,DL,TRANSPARENT.BMP,SEL.BMP,END.BMP,0,50,60
                      My problem is if i change the variable path value into my settings , i need to do a reloadscreen or reloadskin if i want to see the good value into the screen where are these lines !
                      1-Does exist another method ?
                      2-Is it possible to have the possibility to use label as path into the SD line (because always updated)?
                        i think this topic should be an own thread.
                        what happens when you use the cmd SETPATH?
                        RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
                        RR-Plugin: IBusCommunicatoRR new Updates
                          My plugins have their own file browser coded in them (when they are needed) and I just use a custom list.
                            Thanks Enforcer for your help ! In fact it's an idea , but i should like use the SD list method if possible !
