about visu transparency
  • about visu transparency
    Hello, I'm using WMP, but I would like to have on my skin, some slider to change the transparency of visu
    as I can do that?
    an other simple method(workaround) could be:
    if you add buttons to calculate the var OpacityVisu in 1 or 10 steps
    but i don't know what happen, if you go out the range 0-100.
    ButtonCommandCode
    Code:
    eval;OpacityVisu;$OpacityVisu$+1
    eval;OpacityVisu;$OpacityVisu$+10
    eval;OpacityVisu;$OpacityVisu$-1
    eval;OpacityVisu;$OpacityVisu$-10
    RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
    RR-Plugin: IBusCommunicatoRR new Updates
      i found time to write a little "helper" for you.
        hi , thanks harry ,I drop it and add the folder in the plugins folder, right? register it and add a slider with that command
        "SLDOpacityVisu"
        but does nothing? or should add?
          The slider has the same name like the var = opacityvisu
            perfect , thanks so much , work perfect
              added the cmd to save the var to ini.
                hi , i check in skintool and see this
                SldrSet: opacityvisu : 40671
                SAVETOINI;OPACITYVISU;62
                ONSLDopacityvisu
                but into skin.ini but dont see nothing
                oh , i check again , into rr.ini , i see there
                [Audio Player - Visuals]
                VisuName=WMPVis
                TransparentVisu=True
                OPACITYVISU=22
                I thought it was in skin.ini
