RR 03/01/2014 Release
  • RR 03/01/2014 Release
    Damm its cold out!
    Download HERE
    just 2 little issues...
    HISTORY:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    2/14/2014
    # Fixed "ONDLPOSCHANGE" Event, took different approach to generate this event
    # Fixed other indicators to use literals "True" and "False" so they arn't local affected
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thanks Mitch.
      Houpy , a new version :-) Thanks .
        Much Appreciated Mitch!
          Thanks, Mitch.
            Hi Mitch i updated to new RideRunner now my main logo that is a mercedes logo that has transparency on the cornres show as white the corners, the transparent thing doesnt work anymore, i will try to upload a photo.. any ideas? thanks! I have XP, latest riderunner, an latest flash (13).
            Click image for larger version
              this is a flash issue, and I really cant figure it out...
              if I build rr with flash 13 on my win 8.1 machine, that's what u get
              if I build rr with flash 13 on a virtual win 7 machine, seems ok
              the thing is it shouldn't matter, as flash is loaded outside of RR
              its puzzling... but for sure a FLASH issue
              I have a RR built on my virtual win7 machine, if you want it pm me
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                which brings up a question, what is you're OS?
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  i use win xp! can you send me the version of january of ride runner, all was ok with that version? also, i can't register ride runner, when i try to send the hdd serial it says time out, seems that the registration is not working.
                    i thought it could be a problem with flash too, my previous version was from january and all worked just fine, so now after the update and problem i updated the flash to latest and all still the same. I could just disable the logo, but looks so damn nice the logo in the center when it shows as is supossed..
                      its just that when I build RR on the windows 8.1 machine, the transparency issue show up, but not on the windows 8.1 machine
                      on OLDER OS
                      if I go and build same RR on a windows 7 machine, there is not transparency issues, yet both are running the SAME FLASH
                      I cant figure it out...
                      its a real pita!
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        A simple Question about the Logo.
                        Normaly the Logo is a Image, for what you need a flash player ?
                        AND it must be an .png File, otherwise its not transparent.
                        I tried with XP, Win 8.1 and Win7,
                        in all installs the logos and all flash player(13.0.0.206) files working perfect.
                          on OLDER OS
                          its a real pita!
                          I just setup my new carpc last week. With the latest RR + Flash 13, on my WIN7 built. All flash files transparency don't work anymore.
                          When I re-install RR ver Aug 2013 + Flash 11.3 it works well. Just to share my findings.
                          Mitchjs, how can I activate my RR offline? The online activator don't wok anymore.
                          Intel D945GCLF2, Lilliput 629GL-70NP, GTop MTK GPS, Road Runner, DFX4, Winamp 5.13+Console+VST->HotAudio DAC->NXS 400.4 + NXS400.2 DSP Amplifiers + DSP Software Processing->Dynaudio 340 3 Way Active
                            on OLDER OS
                            its a real pita!
                              I converted the logo to .png using photoshop and transparency, but still the same, doesn't work.. can anyone send me the link to download riderunner january version? thanks!
