remedia install problems
  • remedia install problems
    Hi guys,
    can somebody make an step by step on how to install remediacar and which and what in what order to do
    i would really like to try this out but cant get it to work.
    any help is greatly appriciated.
    gerard
    time for the sig:
    '00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
    Read the readme.txt , configure whit Remedia.ini your adapt data.
    Mauri
      Hello Gerard,
      I have just installed remediacar, and am impressed with the interface ! I just now need to get it to work. You need to make sure you have downloaded the mediacar app first. I installed this in the same directory as ReMediaCar. You also need to download at least one skin ! Then open the remedia.ini file and make sure that the directories point to the right places. When you get that sorted, the app visual app should work.
      That is were I am up to at the moment ! Good Luck.
      regards
      KPJUK
      M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
      DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
        Originally posted by kpjuk
        Hello Gerard,
        regards
        KPJUK
        You need to instal Winamp and Media Player Classic first, then unzip the Remedia files anywhere you want to run from. Edit the the Remedia.ini with your settings and that's it. There is a readme.txt with details of each setting, also on my links page (http://guino.home.insightbb.com/links.html) there's a link for the files you'll need to download, including two full skins (if you don't want to get them elsewhere). MediaCar has never been required to run my software, although, that does provide you a set of skins to play with -- the updated skins will provide you with a few extra options not included in MediaCar.
        Ride Runner RR's Myspace
          I keep getting an error messgae saying that I don't have a valid skin.
          I've tried pointing the remedia.ini at 3 different Media Car skin folders and I get the same result with all of them.
          Could someone lay it out in detail for me please.
          : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
          : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
          : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
            You must point the skinpath to the location of a FULL valid skin (i.e. C:\program files\mediacar\skins\BrushMetal\ -- If you have the brushmetal skin in mediacar). You can download a full skin off my website (see the bottom of links page) or look around for some.
            This path is where all your image and menu files including mainly the "general.ini" and "menu.skin" files. If you get this error there's really only three possibilities: 1-the path is wrong, 2-the skin is incomplete or 3-the skin is invalid (invalid data) you should NOT enter the name of any file, just the path ending with \ )
            Let me know if you still can't get it... check readme.txt for details on other settings.
              OK, fixed it. I was just being a bit ( or a lot ) thick.
              I hadn't put the "\" onto the end of the path to the skin and that's what was casuing it to not work. !!
              I'm happy now.
              Yeah, I know, little things please little minds.
                I have created an Install program for this. Just waiting on Guino to take a look at it, and let me know if he wants to use it or not.
                Should help fix alot of Install issues.
                2000 Yukon Denali
                Shuttle SN65G2
                Cel-D 2.4 GHZ 533mhz FSB
                1GB PC800 Mem
                Radeon9200 PRO
                Seagate 120GB
                ATI Remote
                RF Mini Kb w/Trk Ball
                7" Lilliput Touch Screen Monitor
                USB 2.0 Hub
                Rikaline GPS-6010
                PN11 802.11b Wireless
                XP Pro
                750W Inverter
                  hows it going?
                  gday,
                  love the work you guys do... how's the install program coming along?
                  Hilux Surf (4runner) install
                  false floor in rear housing;
                  4 channel amp
                  600w cont. inverter.
                  Also- DigitalWW 7VGA indash
                  headunit for FM/AM,DVD,SVCD,CD,MP3
                  P4 3.0 with low profile AGP card.
                  4x4" speakers (splits) in factory locations
                  BU-303 GPS
                    Originally posted by fishy
                    gday,
                    Ask bry21317 (above) if he can make an updated install -- I'd make it available on my site.. I have not worked on it personally because it takes way too long (relatively) to keep it up to date.. besides, RR doesnt really NEED to be installed, you can just unzip it somwhere, use the config tool to define your settings and you're done..
                      Updated File at 4:45 EST 2-3-05
                      Click Here to download my RoadRunner 2/2/2005 Install.
                      NOTE: This install will only work for XP or 2000. This doesn't support Windows 98 or ME.
                      This file is 18.9mb in size to include everything that is needed. Also, this has been moved to MoreMods Server so it is much faster for download.
                      Thanks for the help MoreMods!
                      This will do the following and make the following Directories:
                      1) It Installs the Brushed Metal Skin from Guino's website, with the Updates.
                      2) It Copies the Road Runner Files as of 2/2/2005 release to the following Directory: C:\Program Files\Road Runner\.
                      3) It copies the mediaplayerc.exe file to the C:\Program Files\Road Runner\ directory.
                      4) It copies the Gama files to a C:\Program Files\Road Runner\Gama Directory.
                      5) It creates a Desktop Icon, and also a Pograms Group for Road Runner, off of the Start Menu.
                      6) At the end of the Installation, it opens the Config Program so that you can make any changes that you might need. It will also show you the Readme.txt file.
                      7) Installs the Fonts for the above Skin to the correct Directory under Windows 2000 or XP.
                      If anyone has any suggestions, that will make it easier, let me know and I will try to change what is needed.
                      Also, if you install this and get any future Installs, you can just use the Update Command. You will see this if you install the Program, and then try to install it again, it will state Update and Remove as options.
                      Thanks,
                      Bryan
                      2000 Yukon Denali
                      Shuttle SN65G2
                      1GB PC800 Mem
                      Radeon9200 PRO
                      Seagate 120GB
                      ATI Remote
                      USB 2.0 Hub
                      Rikaline GPS-6010
                      XP Pro
                      750W Inverter
                        champion
                        a-ha, you're a champion i can put that "learn VB6 in 21 days" book away now...
                        i'm d/loading now, crossed fingers it all works fine...
                        again, many thanks all, for making such awesome contributions to the carPc community.
                        4 channel amp
                        BU-303 GPS
