Road Runner Installation Program
  • Road Runner Installation Program
    Updated File at 10:45AM EST 2-8-05
    Click Here to download my RoadRunner 8/21/2005 Install.
    GUINO> Last known working link:
    http://www.majesticpw.com/roadrunner...ner8-21-05.exe
    NOTE: This install will only work for XP or 2000. This doesn't support Windows 98 or ME.
    This will do the following and make the following Directories:
    1) It Installs the Brushed Metal Skin from Guino's website, with the Updates.
    2) It Copies the Road Runner Files as of 2/8/2005 release to the following Directory: C:\Program Files\Road Runner\.
    3) It copies the mediaplayerc.exe file to the C:\Program Files\Road Runner\ directory.
    4) It copies the Gamma files to a C:\Program Files\Road Runner\Gamma Directory.
    5) It creates a Desktop Icon, and also a Pograms Group for Road Runner, off of the Start Menu.
    6) At the end of the Installation, it opens the Config Program so that you can make any changes that you might need. It will also show you the Readme.txt file.
    7) Installs the Fonts for the above Skin to the correct Directory under Windows 2000 or XP.
    If anyone has any suggestions, that will make it easier, let me know and I will try to change what is needed.
    Also, if you install this and get any future Installs, you can just use the Update Command. You will see this if you install the Program, and then try to install it again, it will state Update and Remove as options.
    Thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    I'm downloading right now, so I don't know how it works yet, but I think this is a very welcome tool for many of us. And it should have been made long before!! Also for other FE's!
    Finished!
    pc 99% - install 100% - audio 100%
      Let me know, I have made it as easy as Possible. I can do pretty much whatever we need in this, I could also find away to make it install the Mediacar, if needed, so let me know what everyone thinks.
      I know that I had problems, right at first when I was trying to get Road Runner set up, my problem was that I forgot to add the fonts. So, we all make mistakes, and this should greatly help, since there are so many little pieces that you need to do to make it all work correctly.
      2000 Yukon Denali
      Shuttle SN65G2
      1GB PC800 Mem
      Radeon9200 PRO
      Seagate 120GB
      ATI Remote
      USB 2.0 Hub
      Rikaline GPS-6010
      XP Pro
      750W Inverter
        Hey bry21317,
        A few problems I found ---- gama folder incorrect - needs renaming to gamma.
        Skins folder doesn't appear in the ini file upon installation. No other problems as yet - manually altered to work.
          When you say, the Skins Folder doesn't appear in the .ini file after Installation, are you sure this is correct? I am not having any problems with this.
          I did find the Gamma folder was incorrect, and am fixing this right now.
          I will be checking and updating this link on my site pretty soon.
          2000 Yukon Denali
          Shuttle SN65G2
          1GB PC800 Mem
          Radeon9200 PRO
          Seagate 120GB
          ATI Remote
          USB 2.0 Hub
          Rikaline GPS-6010
          XP Pro
          750W Inverter
            Well ..... as the brushmetalhonda is installed as default surely it should point to here???
            Maybe I'm wrong
              Problems with WinAmp and RR
              Hi, I'm new and I had download Road runner.
              I can't see the video in RR window but I must clik on winamp and it isn't embed.
              my winamp is 5.08 pro
              Can anyone help me please?
              Chrysler 300C Touring 2006 CRD
              My ex car - Alfa 147 project
              Italian Rock Band! http://www.pikasso.it
                Didn't work for me...
                I get a - run time error '76' - path not found - error.
                I checked my config setting, and can't find any false path's...
                Also few suggestions
                Add an option to choose a quick launch icon besides the shortcut.
                Include winamp install if possible, or is that a copyrighted programm?
                maybe a option to choose what to install or not, if it's already on your pc.
                Finished!
                  Phythorian, rename c:\program files\road runner\gama to c:\program files\road runner\gamma
                  and also make sure that there is a path in the rr.ini after the skins=
                    Yep, That did the trick!!
                    Now it works for me!
                    I had RR installed allready, but I think these kind of prog's makes live a lot better!!
                    Thx !
                    Finished!
                      I am uploading a new version currently, but it seems their was a pretty high interest for this, as my server is running dirt slow right now.
                      So its telling me that it might take 30 minutes for the FTP transfer.
                      I fixed the Gamma issue as found by UK_MP3Car, thanks.
                      I also checked all the settings for the Skin, and they are all working fine on my system. You might have had an old .ini file on your system that didn't overwrite for some reason, or if you clicked on this path in the Config window, that popped up. This is all that I can think of, it works fine on my system. So I will let it fly for now.
                      I will post when it is all uploaded to the newer version, that fixes the Gamma, Typo! Darn, fingers.
                      Thanks,
                      Bryan
                      2000 Yukon Denali
                      Shuttle SN65G2
                      1GB PC800 Mem
                      Radeon9200 PRO
                      Seagate 120GB
                      ATI Remote
                      USB 2.0 Hub
                      Rikaline GPS-6010
                      XP Pro
                      750W Inverter
                        File has now been updated.
                        2000 Yukon Denali
                        Shuttle SN65G2
                        1GB PC800 Mem
                        Radeon9200 PRO
                        Seagate 120GB
                        ATI Remote
                        USB 2.0 Hub
                        Rikaline GPS-6010
                        XP Pro
                        750W Inverter
                          Is there a way to continue to use his updates? Can I just move the new files into the directory in myrogram files files directory?
                            Yes,
                            Just copy over the New updated Files, and it wil all still work correctly.
                            Thanks,
                            Bryan
                            2000 Yukon Denali
                            Shuttle SN65G2
                            1GB PC800 Mem
                            Radeon9200 PRO
                            Seagate 120GB
                            ATI Remote
                            USB 2.0 Hub
                            Rikaline GPS-6010
                            XP Pro
                            750W Inverter
                              This typically means either of the two:
                              -You don't have Media Player Classic Installed
                              -You don't have the correct Media Player Classic Path setup (Run RRConfig and set/check the path -- should end with mplayerc.exe, or appropriate name)
                              You can download MPC from the links section of my site.
                              Let me know if still doesn't work,
                              Guino.
                              Ride Runner RR's Myspace
