ID3 Tag Information, how to make it work?
  • ID3 Tag Information, how to make it work?
    Guino,
    I have a question, such as that Road Runner is showing my files such as 1014.Take My Breath Away without artist anme or anything, when trying to use the ID3 Tags. Here is an Image of my Player with a song selected and playing.
    Here is the Text from my .ini file so that you can see all the settings that I have selected:
    voice=false
    musicpath=F:\Songs\
    videopath=Click here to set path
    cddrive=c:
    dvdpath=Internal
    launchpath=C:\Program Files\MediaCar\LAUNCH\
    winamppath=C:\Program Files\Winamp\
    skinpath=C:\Program Files\Road Runner\skins\BrushMetalHonda\
    mpcpath=C:\Program Files\Road Runner\mplayerc.exe
    screentype=16:9
    videoautohide=false
    videohidetime=4
    hidemouse=false
    useid3=2
    showid3playlist=true
    showid3browse=true
    gpsmode=0
    mapmonkeypath=C:\DestinatorApps\Map Monkey\MapMonkey.exe
    gpspath=C:\DestinatorApps\Map Monkey\MapMonkey.exe
    gpsname=Map Monkey
    exitmode=4
    showicons=true
    showextensions=true
    titlesafter=-
    listfollowssong=true
    resumemusic=false
    audiorepeat=off
    audioshuffle=on
    gammamode=1
    gammapath=C:\Program Files\Road Runner\Gamma\GammaControl.exe
    dateformat=DD/MM/YY
    timeformat=HH:MM:SS AM/PM
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    @bry21317:
    This isn't a bug or your false. At the moment "only" ID3 titles are displayed in RR. But Guino is working on options how ID3 will be displayed, soon
    e.g. artist - title or album - title,...
    Give him time..
    Winni
      Thanks for the Info. I wasn't sure if he had fully finished it or not, this is why I was asking.
      Thanks,
      Bryan
      2000 Yukon Denali
      Shuttle SN65G2
      1GB PC800 Mem
      Radeon9200 PRO
      Seagate 120GB
      ATI Remote
      USB 2.0 Hub
      Rikaline GPS-6010
      XP Pro
      750W Inverter
        Version 2-7-05 does what u want.. (Custom ID3 Formatting)
        Ride Runner RR's Myspace
          He's lightning fast!
          Thanks!
            How do we enable the custom ID3 Formatting??? I have changed the UseID3 tag in the Ini file but it doesn't seem to have change it much, is there any way to make it do similar to:
            The only reason I ask is I have just spent hours redoing all the ID3 Tags on my albums
              Do you have the latest release of RR?
              Then start RRconfig.exe, scroll down to music settings and you can edit ID3 tags for PLAYLIST and BROWSE (e.g. %artist% - %title% )
              Or you can still load the ini and add the following lines (but you still need the latest release):
              id3listformat=%artist% - %title%
              id3browseformat=%artist% - %title%
              Have fun!
              Winni
                Ahhh ok - haven't run rrconfig - I always edit the ini files directly, will take a look now
                  If you're going to use tags, you better have them correct (j/k).. If the tag is completely not found, RR will default into the next tag, if that is not found either, then it will use file name formatting (like first versions). Now if the tag is incomplete, well you'll get incomplete names, wont you ? :|
