RR with ATI Remote Wonder anyone?
  • RR with ATI Remote Wonder anyone?
    Who here is using the ATI remote wonder with RR? If you do, what buttons are working? I can only get the volume buttons to work, you would think you can do much more with such a powerful and HUGE remote control!
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
    I'll try to get my "dusty" ATI remote control out of the closet and give it a try today.. I'll let you know how it goes...
    Ride Runner RR's Myspace
      thanks bud
        I`m not using ATI wonder but a remote from "medion" and it works fine.
        I just use the "X10/ATI Remote control interface" as only plugin in girder329.
        Not using all of the possible buttons but calling up gps video dvd music and
        all the typical music commands - it works fine
        memy
          how do u setup calling up gps and all that in girder? im new to that app... thanks memy
            - put the plugin ("X10/ATI Remote control interface" should also work for you) into the girder plugin folder
            - activate it via settings/plugins (should be highlighted -green)
            - select "auto enable input divice"
            - "Apply"
            - the remote should be recognized by girder (green light in the down right corner of girder)
            - select "Launch girder on startup" in Settings/genreral
            - select "Hide on startup" in Settings/general
            - open the rr.gml
            - click on the command you want to pass over to your remote (left hand window)
            - "learn event"
            - press the disired button on your remote
            - save
            I think thats it..
            hth
            memy
              awesome... ill try it out 2nite... this will work with my RF remote? (doesnt it have to be IR to work with Girder?)
                looks like:
                http://www.promixis.com/downloads.ph...er&lucCode=800
                there is a plugin for ati...
                  alright, ill check it out tonight... thanks!
                    I have been testing it and works really well... I'll make a full GML file configured for the ATI TV and post it... what you want to be sure is that your remote wonder software (from ATI) is NOT running along with girder... this might be obvious for most, but some simply forget about it...
                      so i should only have girder running??? is the remote gonna work if the ATI software isnt running? (thanks btw)... looking forward to that girder file!
                        DO NOT run the ATI software along with girder or it probably wont work..
                        attached my ATI remote girder file... I need to add a few preventions againt hitting the wrong keys here and there, but it works really well.. I might even get a girder license to use it in my car...
                          arent you already using it in your car? thats what im gonna use girder and the remote for! thanks for the file btw..
                            memy... what version of girder can i use ? also... which dll do i need to use cause the plugin your referring to is not available on the girder website, the link is down. if someone can post the ati/10 remote plugin i would appreciate it. Im trying girder 2.3.9 and it doesnt seem to work with some of the dlls, it asks for version 3.2. Suggestions? thanks!
                              just tried the GML file and no go... hmmmmm im using version 3.2.9 of girder
