RR 2-19-05 .. little things..
  • RR 2-19-05 .. little things..
    A few more changes to RR:
    I STRONGLY suggest to update your brushmetal/alpine skins.
    -Added Song Title Scroll (2 modes)
    -Added Semi-M3U support
    -Added Built-In Gamma Support (from general.ini file)
    -Added Album Text Art Support
    -Added extra Map Monkey info for skins
    -Added separate Shuffle and Repeat skin commands
    -Added "QUIT" command to exit RR from any screen/menu
    -Added "overspeed" indicator
    -Added Map Monkey GPS Skin with MM's info
    -Added VIDEO_TS folder "skip" feature
    -Fixed Taskbar "bug"
    -Fixed Playlist-not-updating bug
    Also, I've gathered all flash logos from ildena's posts and included them in the Full Brush Metal Skin.
    For the users that will complain about map size in the Map Monkey Screen:
    -Disable your Info bar from MM and you'll get back your space OR:
    -Rename/Replace the .skin file with "old DESTINATOR_GPS.skin" for old style
    For those who will wonder how to set the gamma for a skin:
    -The config tool needs to be updated to allow editing the gamma settings of each skin. (Anyone up for the job ? -- say Mr. Wizard?). For now, edit the gamma settings in the general.ini file of each skin (each color ranges from -100 to 100 in gamma)
    Let the bugs begin...
    Thanks for your great support so far!
    Guino.
    Ride Runner RR's Myspace
    so besides changing how the song title scrolls, what else do we have to do...using old alpine skin....thanks...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      For the old alpine skin, you can go on the audio_player.skin file and find the line that ends with: "TRACKNAME",
      make it end in: "TRACKNAME","scroll"
      that's all... the alpine skin update at my page does the above... if you don't have vis working on it yet, and perhaps no video slider, the update in my page also adds those things.
        THANKS....Thats AWESOME!!
        DFX 5.1.1 Skin
        Appstore Link
        RRMedia
        RRExtended
        DFXVoice
          don' know if anyone has brought this up, but I did at one time try using your alpine skin updates, but the buttons where all messed up and I had to change all the cords to the origanal ones and then it worded fine. I haven't tried any lately cause I didn't want to possably go through all that again...what is the res of the update skin that you have on you site?
          DFX 5.1.1 Skin
          Appstore Link
          RRMedia
          RRExtended
          DFXVoice
            Ummm... the alpine updates at my page are for the 848x480 screens.. if you have the 800x600 version, then what you're saying might happen. in that case, I'd just look athe the .skin files and add the sliders and scroll functions manually by seeing what's different.. I made sure to have a 800x600 (brush metal) and a 848x480 (alpine) skin in my page.. but those are mostly as examples.. as new skins come out for RR you should not need to be messing with this kind of stuff..
              yep that was the prob. i use the 800*600 ones...do more people use the 848*600 then the 800*600, is that why you chose to use that one...
              DFX 5.1.1 Skin
              Appstore Link
              RRMedia
              RRExtended
              DFXVoice
                It was a choice sole made by variety.. I wanted one skin 800x600 and one 848x480.. that's all.. I use 800x600..
                  If I send the QUIT command.
                  PowerVoice v1 | NaviVoice Source
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
                    Is that through the SDK ??
                    if so.. I don't think I can support that function from SDK.. that and "exit" can really crash because of a window hook that will be "untied" when you ask it to quit (while still executing the window procedure).. I may do some research on that..
                    now, if that's directly on a skin, please tell me which screen/skin you used it in..
                      That's through the SDK. I don't want to send the term signal, so I figured I'd send it through the SDK just like I did with Frodo
                      GammaControl v2.4
                      SKINbedder v3
                      1995 Lexus SC300
                        Scrolling title is sweet and very smooth!
                        Seems to be a bug in in the album info though. When inside the actual folder that contains the .txt file it isn't displaying the text file. Instead the first mp3 is hightlighted and the dir. is displayed.
                        It's the cake having/eating thing.
                          ummm.. haven't done extensive testing with that.. actually I only have your skin to try it with.. I'll look it up...
                            You can send a WM_CLOSE to RR, it has support to propperly shutdown when doing so.. (i.e. sendmessage RRHwnd, WM_CLOSE, 0, 0 -- where RRhwnd = findwindow("RoadRunner", "")
                            I'll try to make the sendmessage work too, but I'll only know if it will work when I actually try the fix..
                              Guino... u are my main man... i'll jump right on the release... now
                              Food goes in here..... that's right ... mmmmm
