Map Monkey Maneuvers
  • Map Monkey Maneuvers
    Hi!
    I've got a problem... Since when I installed RR, Map Monkey can't lower winamp volume when approaching a maneuver. I have Winamp volume set at 100% and I choose to change the volume at 80% when Map Monkey is "speaking". However, the volume remains unchanged.
    Has anyone the same problem?
    Thanks a lot!
    Garo
    Garo
    Author Of:
    CarPC Installation on my Seat Toledo
    Originally posted by garo
    Hi!
    Thanks a lot!
    Garo
    I've had this problem since I can ever remember having Map Monkey .. but in my case it does it here, and not there, then again here and not there.. I really doubt this is a RR issue.. I mean, try and run MM outside RR and see if it works right.. Hopefully do the test for the same track (NOT Backwards either)..
    Ride Runner RR's Myspace
      May it depends from the winamp version or similar?... I both tried with 5.08 and 2.95 however, and nothing changed... It should be simply a problem between MM and Winamp, right?
      Garo
      Author Of:
        Sounds right.. in my case, MM only seems to fail with the volume when it has just changed volumes.. for instance, 2miles and 500 yards volume is lowered, then 200yards and the turn voice come up a lot of time without volume lowered.. I assume it has to do with the timing.. but I'd double check your MM settings are set for Winamp etc..
