Shuffle always on?
  • Shuffle always on?
    Hi Guino & Others...
    Why is it that RR always starts up with shuffle enabled in the music? I can turn it off, but if I restart RR it comes on again... it is kind of annoying cause I sometimes forget to turn it off, then I loose sequence of my playlst...
    I also looked at screenshots of the skins in dev and they all seem to have the shuffle on!
    Roy
    2005 Range Rover 4.4
    Check your setting in RRConfig .. set Default Shuffle Mode to 'Off'
    Lexus SC300:
    Shuttle SB65G2/P4 2.4GHz/512 Meg RAM/120G Drive/Dynamix 706 TS/M4-ATX PSU/Rikaline 6010 GPS/RR/iGuidance 4
    Corvette:
    VIA EPIA SP-13000/512Meg RAM/250G drive/M1-ATX PSU/Xenarc 7" TS/BU-353 GPS/RR/iGuidance 4
      There are 3 Start Modes for Shuffle and for Repeat: ON, OFF and LAST. Last will start with whatever you had last. the other two are pretty obvious.. look at those settings in RRConfig.
      Ride Runner RR's Myspace
