RR 2-23-05 .. Quick Update..
  • RR 2-23-05 .. Quick Update..
    Quick Update while I'm on the go..
    -Built in Video Player (without MPC)
    -Fix for Hide mouse after Hibernation
    -Added prevention from running same screen twice using SDK or remote
    -Added Scan function (for MP3, TV and future radio)
    -Various Bug Fixes
    There's no built in support for playing DVDs, so either use MPC or an external player.
    I am stuck in Flagstaff, AZ until friday without my home computer to update the web site and upload sorces etc. so for now this will have to do:
    Mirror Site
    Let the bugs begin..
    Guino.
    PS: here's what I got back from radiotime.com:
    Hello,
    Sorry about the delay.
    Our tuners are currently on back order. We expect to receive the new shipment and send out your tuner within a matter of days.
    Thanks for your patience. Please contact me if you have further questions,
    Axxxxxxx Bxxxxxxxxx
    Ride Runner RR's Myspace
    Nice!
    How can I add the scan feature? Haven't found anything in "skin commands.txt".
    Built in video works fine!
    Winni
      yeah.. haven't had time to mess with documentation yet..
      make a button with the code "SCAN" and it will cycle through MP3s or TV channels.. you can also set the number of seconds to wait until the next scan by adding a setting to RR.ini:
      scansecs=XX (XX=number of seconds)
        Guino,
        Should I remove the Mediaplayerc.exe from the Installation?
        I am about to update it with this version now.
        Bryan
        2000 Yukon Denali
        Shuttle SN65G2
        Cel-D 2.4 GHZ 533mhz FSB
        1GB PC800 Mem
        Radeon9200 PRO
        Seagate 120GB
        ATI Remote
        RF Mini Kb w/Trk Ball
        7" Lilliput Touch Screen Monitor
        USB 2.0 Hub
        Rikaline GPS-6010
        PN11 802.11b Wireless
        XP Pro
        750W Inverter
          Guino,
          On the built in Video player, is this for DVD's or just other types of Video formats?
          Also, how to you make Mapmonkey use your skin and not use its selected Skin?
          Thanks,
          Bryan
          2000 Yukon Denali
          Shuttle SN65G2
          1GB PC800 Mem
          Radeon9200 PRO
          Seagate 120GB
          ATI Remote
          USB 2.0 Hub
          Rikaline GPS-6010
          XP Pro
          750W Inverter
            I'd leave MPC in the installshield for two reasons: 1-It is still optional (so you can still use it if wanted). 2-DVD playback requires it when not using an external DVD player.
            Map Monkey will always use it's own skin.. The BrushMetal skin at my site has the extended GPS screen for map monkey which is optional.. The skin you choose in Map Monkey is still used, the only difference is that you can turn off MM's info bar since that info is already displayed in RR's skin.
            As always, Thanks for your work on the installshield.
              Just downloaded this- having 1 issue
              When in video and press arrow to go back to main menu- the top part of the screen ie above the video controls disappears for a second ie desktop behind it shows but then menu appears and fine
              edit: same with dvd option and 2 more things
              2) in video when you hold down forward the speed is too fast for me- Im playing music videos of say 3 minutes so when trying to forward a little it goes right to end! any chance of slower or 1x 2x increments? (or a music video option!! )
              3) Im currently using RR on laptop as background music and video, sometimes when video up i like to bring up a browser to quickly check summat but when video mode the video control bar always ontop over Iexplorer (actual video playing does dissapear, when video controls auto dissapear still issue as soon as you go over that area with mouse)
                It is normal for the video disappear before showing the main menu. I can not change this due to the navigation code (so you can always go anywhere from anywhere).
                I'll try to add an option to forward in 20 Second increments for videos of less than say 10 minutes in lenght. It is only possible to set the speed of playback when using MPC and in DVD mode only.
                The only thing you're supposed to do from the video screen is: Select more files, open the mixer. The idea of having a video playing and not watching is just silly to me, so if you want to run IE, please do it while not watching videos...
                  Welcome to Arizona Guino! Make sure you go skiing at Snowbowl.
                  Aopen i855GMEm-LFS with Dothan 1.8ghz
                  512mb DDR333
                  Windows XPpro SP2
                    thank you! I hated that MPC crap.
                    2011 Nissan Frontier SL
                    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
                    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
                      Well, here's what MPC can do that the built in player can NOT do:
                      -Play Videos with subtitle support
                      -Play Audio onto a SPDIF output
                      -Play DVDs
                      -Use specific Plugins and/or codecs
                      For mostly everything else the built in player should work.
                      Just don't come complaining when you have a high-quality divx video with 5.1 AC3 sound and it doesn't play correctly in the built-in player. Although, with good codecs, it should still play.
                        right... I'm stuck at the airport in Flagstaff now, no transportation and my flight is delayed which means I'll not get home today and will be stuck in Phoenix later, with no place to go/stay... so bad day already..
                          if i lived in phoenix... u where welcome at my place i can promise u that Guino
                          Food goes in here..... that's right ... mmmmm
                            haha.. no big deal man... I'm used to take this kind of crap all the time.. what I really need to do is quit my job...
                              So what do you do for Work?
                              Just wondering.
                              Good Luck getting home on that flight.
                              Bryan
                              2000 Yukon Denali
                              Shuttle SN65G2
                              1GB PC800 Mem
                              Radeon9200 PRO
                              Seagate 120GB
                              ATI Remote
                              USB 2.0 Hub
                              Rikaline GPS-6010
                              XP Pro
                              750W Inverter
