8 Outputs control of the pararell port suppert?
  • 8 Outputs control of the pararell port suppert?
    Hello.
    Guino I have a question for you.
    I am going to finish this week a pararell switch board for 8 relees.
    I will use a program to control those relees <- (sorry for english)
    I ma wondering if you could make a on section as you have (video, gps and so on) for relee control?
    You can get a source code from me if you want to...
    I am planing to control neons under my car, insiade my car, a trunk neon and couple of other things.
    I hope you can look at it.
    Ow but the way. Your work on RoadRunner =
    Project done in: [####################] - 85%
    - Custom center console
    - Custom trunk
    Se my project here
    I can add support to control your rele board.. It shouldn't be hard (specially if you provide source code).. I just don't have what it takes to edit any graphics..
    Ride Runner RR's Myspace
      I have been contimplating this also. In my project I was gonna make each relay be able to have a timer, or momentary, or on/off. They would all be easily set in a settings file or from a settings tab from within the program. This way it could control power windows or in my case, power tail-gate. I don't know if you can use one channel to go up and down though. Any ideas?
      2.4 celeron
      150 watt OPUS
      micro atx
      xp pro
      tv/radio tuner card
      audigy
      Dual monitor Radeon
      802.11G Mimo
      xm pcr
      dvd
      gps
      8" Lilliput touch screen
      IGuidance
      dual optimas
      battery isolator
      15" screen
      My Truck
        Here is a c++ source example of using D0-D1 for LPT1
        pinctrl p(0x378, TRUE); // making an object with LPT1 and inverting all ports
        p.set(D3, 1); // sets data line 3 to high (there are D0 to D7)
        bool status = p.get(D3); // Gets status for D3
        Program is using io.dll
        - Custom trunk
        Se my project here
          One idea its to use the control relay board with LPT to climate control of the car.
          Drive the servos present in the climate control with one skin adapt for RR, to simulate the AC air full control,directions of air ,speed of the motor of ventilation, heat and cold, etc...
          The only problem that the cars are not all equal of the climatize control, it needs to adapt the project for you car, however it would be a good dea to use with RR.....
          Mauri
            yes, tehrefor I want guino to mage this support. it will be very great..
            - Custom trunk
            Se my project here
              This is a good idea, but my question is why not add a command table of operations like:
              D0-D7 all Zeros, means do nothing
              D0=1 and D1-D7 all Zeros, means turn rele 1 ON
              D1=1 and D0-D7 all Zeros, means turn rele 1 OFF
              D0=1,D1=1 and D2-D7 all Zeros, means turn rele 2 ON
              D2=1 and D0-D7 all Zeros, means turn rele 2 OFF
              And so on..
              What I mean by the above is to have D0-D7 be used to make up a Byte with 256 Combinations. 0=Do nothing and all other values perform assigned commands. That way, you could control up to 127 Reles (ON/OFF).. or simply use the other commands for whatever else you may need.. I understand that the circuit would be more complex, but it would be a lot more flexible... I'm just thinking for the future.. I for one would like to have reles controlling the 4 windows in my car (Up/Down) which means I'd need 8 reles, which means I couldn't do anything else since I'd have used all 8 reles..
              It is also my understanding that it is possible to read the D0-D7 bits from the paralell port that can be set via the connected board. So the above command table would simply set the command and the board would automatically set it back to Zero after completing the command. The software can definitely be made smart enough to keep track and display the current statuses without having to query the board..
                Simple search:
                Very easy simple project to control 8 relay to LPT port.
                Link http://www.geocities.com/dsaproject/...lay_board.html
                Complete link to download the Windows sw for this project
                http://www.geocities.com/dsaproject/...downloads.html
                In this project is used relay to 24V;
                but its possible to use another relay to 12V , not problem...
                In Internet many project to control multiple relay with LPT PC port....
                Mauri
                  talking of 8 relay LPT board try:
                  http://www.quasarelectronics.com/
                  I have one of their boards and they are really easy to program with VB.
                  Don't quite know what i'm going to use it for yet but it looked worth playing with.
                    The Quaser relay board looks good, even comes with an OCX to allow programming with VB easily.
                      My personal idea is:
                      all project i make home made , not kit to purchase
                      Mauri
                        You're lucky like that, I'm a computer Engineer and its the Hardware side of things I'm good at, i.e o/s installs etc, unfortunately I don't have the knowledge to build my own relay controller etc, so I'm forced to purchase things like that.
                          If it goes out some good idea of to use with the controller to LPT and 8 relays I can build after the hardware of the link posted
                          and then if works put on line for all... before it takes the idea however on as to use....
                          Mauri
                            So do any of these boards get past the parallel port boot up problem?
                            i.e. when you boot up, the parallel port gets random bits sent to it thereby inadvertantly activating the relays attached to them during boot.
                            StreetDeck.com Developer (I am Chuck)
                            Get StreetDeck at http://www.streetdeck.com
                            The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
                              I think this is no a "problem" this is a windows feature that at boot time, tries to find devices attached at the LPT ports and install them .. if a home made board is done, it is more than possible to assign a special code to "activate" and "deactivate" the board, that is prevent it from receiving commands until instructed to do so..
