Auto launch application help ??
  • Auto launch application help ??
    I am trying to add some more screens to my skin (like file sync, info screen ...)
    After I load the screen, is there any way to launch an application and imbedded it in the screen without pressing a button. I tried the RUN commands by themselves but had no results.
    This is the syntax of how I used the run command.
    "RUNQ;C:\transfer\transfer.exe;TRANSFER"
    "A,036,077,773,365,000,000,000"
    The road is long but we are getting there.
    Use the LOAD command code:
    "LOAD;<PATHTO.SKIN>;<SPEAK TEXT>;<PATHTO.EXE>;<WINDOW TITLE>"
    For instance:
    "LOAD;EXTERNAL_GPS.SKIN;Destinator GPS;Destinator3.EXE;Destinator"
    You should use a different .SKIN file for every application you have, that is, if you may want to use/run them at the same time. The new .SKIN files may just be a copy of the existing ones with a different filename.
    Ride Runner RR's Myspace
      Thanks for your help Guino
