No sound (music)
  • No sound (music)
    I have just tested RR for the first time and it looks very nice
    But I have a problem mybe someone can help me to solve...
    I have no sound when I play music? but when I tested videos it works with sound?
    Could it have anything to do with win media player clasic or winamp?
    When I launch the music section I can see the songs but thats all nothing more happens?
    /Rs!
    sounds like winamp is not starting for some reason.. the most likely reason is that the winamppath setting is wrong... re-run rrconfig and re-select that path, then you should be able to use it.. also you may want to turn off that "hide winamp" option just to verify winamp is running when RR is trying to play music.. if winamp doesn't start RR won't be able to play any music or use TV functions.. You might also want to check winamp's volume.
    This is most definitely nothing with mplayerc, nor related to video.. if you try the above and it doesn't work, please add this line to your RR.INI :
    debugmode=true
    Then re-run RR, try to use music, then post your RR.INI and debug.txt files as attachments.
    Ride Runner RR's Myspace
      Hi again, and thanks for your quick reply!
      I thougt that winamp was included....but now I know itīs not so I downloaded
      and now it works...
      Another question: is it possible to change the honda brand who is spinning to
      my car brand? and if so how is it done?
      Thanks!
      /Rs!
        You can look for your car logo here
        http://www.mp3car.com/vbulletin/show...0&page=1&pp=15
        www.vortexleather.com
          vortex beat me to it.. just get the logo on the thread and replace the logo.swf file in the skin folder with it
