Road Runner on Xp nlited no buttons working
  • Road Runner on Xp nlited no buttons working
    hi, i made an nlited copy of windows xp pro integrated with sp2, two versions, one is the full package+sp2 and the second one is the diet version wherein i stripped the stuff that i dont need to run xp pro. results on boot time is fast (at least faster than my windows 2000 pro setup), but the problem is when i installed road runner, non of the buttons work at all. try clicking them, they depress but no actions. anyone had this problem? thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    do you have Winamp installed ? can you make me a log file ?
    Ride Runner RR's Myspace
      unfortunately, i was not able to make a log file, yes i got winamp installed. it acted weird also, when i exit RR using ctrl+alt+del, then winamp just acts up saying the demo words it says when you first install it. i will try it again maybe this week, i will make log file next time. oh yeh, how do i get the log file? i did not do it before since i dont know where to look and so frustrated. thanks
      7" Lilliput
      Opus 150
      mini itx 1Ghz
      1GB sdram
      97 Prelude
        to make a log file.. add this line to RR.INI:
        debugmode=true
        then run RR and make it freeze or whatever..
        Also, you should NOT use winamp Lite -- must be full version, and you MUST NOT use a modern skin.. other than that.. I'd make sure that you have the flash player from macromedia installed (must use I.E. to install it). Some people have reported "freeze" up when loading the skin because of bad flash versions -- do you see the Logo spinning on the skin? if not, that may be all of your problems right there..
          oh, i always used winamp lite in all your versions of RR and worked ok for me. but yes the spinning logo is there and is cool. i will try tonight or tomorrow and post it thanks man
          7" Lilliput
          Opus 150
          mini itx 1Ghz
          1GB sdram
          97 Prelude
            Use of WinAmp Lite will make the mixer (Equalizer) screen useless, and possibly cause issues with the playlists.
            89 Supra Turbo
