problem updating RR?
  • problem updating RR?
    Time to make my self look like a fool
    I have problem updating RR....this is what I have done:
    I download Binary.zip & Source.zip and extract them to Roadrunner map,
    and when I start RR again it complains about skinfile not correct something.
    When the update is done, the config file is changed so I change it back to the directions I had before but it still complains about skinfile VBStuff something?
    Am I doing it wrong???
    /Rs!
    /Rs!
    yes, pretty much..... to update, simply download the BINARY package ONLY and unzip it over your files. It will not mess with your INIs, settings etc -- But you should always run RRConfig afterwards to make sure your settings are correct.
    The Source package has config and INI files I leave in there for example only, but they'd be overwriting your current settings and INIs -- so no good if you're NOT developing stuff in/for RR.
    To fix your current state: simply run RRConfig and set all your settings as you wish... THEN you should delete the RESUME.INI file to prevent RR from trying to resume music, shuffle&repeat AND more importantly the last skin used -- it will load the skin setup in RRConfig.
    That's all,
    Guino.
    Ride Runner RR's Myspace
      Guino, can you please have the RRConfig delete the resume.ini file when saving, I always forget to delete when I change something...
        Yeah, I've been meaning to do that.. I'll write it down this time.. it's really like 1 line of code..
          Thanks!!!
