HELP!! RR can't find skin
  • HELP!! RR can't find skin
    I'm wanting to use RR but I keep getting
    "E:\App\Road Runner\Binary\Skins\DEFAULT does not contain a valid skin! Check your settings and try again." I've check everything and I still can't get it to work.
    Am I an idot and put the skin in the wrong place? Or am I just a moron? Because no one else seems to be having this problem.
    Run RRConfig and make sure the path is set correctly.
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
      Just remove the dir DEFAULT?
      Or set the skin directory 1 level up (to ../skin instead of ../skin/default
      As far as I know, RR looks in that dir, and directory-names are the skin names.
      Otherwise you can edit/view rr.ini manually
      *can't check it myself now, i'm at work, car is in parking space outside*
      My Opel Astra 1993 CarPC:
        check to see if you have a resume.ini file in your RR directory.. if its there delete it. Then try again
        Follow me on Twitter
          Thanx to everyone with your speedy replys!!!! As soon As I posted the problem I went back and moved the folder and it works now!
          Thanx everyone!!!!!!!!
            O.K. now all of my sliders flicker. Why would this happen?
              You probably have sliders with the Y definition.. open your .skin files for the screen with sliders and simply comment out (add a '/,' in front of) the lines that start like:
              This typically happens with older skins only.. it is faster anyway if you don't have that definition in there -- but this might remove the background effect on your sliders (if any is in place).
              Ride Runner RR's Myspace
