canīt play video in RR
  • canīt play video in RR
    i have a problem i canīt play movies in RR but if i swith to centrafuse i can play all the movies i have installed all codec i think i need. but it happends nothing when i click play
    Http://www.zinknet.se
    Carweb 2.0 NOW FOR DOWNLOADING
    Me neither, just installed RR. I've tried disabling the built in player but still nothing happens when the video button's clicked. Media player classic works outside of RR.
    I've even tried setting the default file associations to media player classic but that makes no difference either. The video browser just doesn't appear.
    Mazda 323F
    Lilliput 7in
    Toshiba Tecra, MapMonkey, DVD, EZ Sync, Roadrunner
      See if media player classic works outside of RR, then check if the correct directory is set in RR that points to it.
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        If you click video and NOTHING HAPPENS (the video player doesn't even appear) then you have some kind of skin issue.
        If you click video, and the video player appears, but nothing is on there, it is very possible that you just don't have the path to your videos setup correctly..
        If you have made sure this is setup correctly, then try changing the "Built in player" option in RRConfig...
        Everytime you try the video player you should go into the video BROWSER and select the files to play -- because the resume information will probably be invalid from before.
        The builtin player works with MCI (Windows API only) -- if it doesn't work it's something on your machine preventing it from working right.. If MPC works outside RR it should work in in RR as long as the path is correct (basically RR only controls it through the skin).
        Ride Runner RR's Myspace
          I'm using the brushmetalhonda skin that came with the installer, and on 2 different machines, car pc and laptop, the video browser doesn't appear. Media player classic works outside of RR and the paths are correct.
          Mazda 323F
          Lilliput 7in
            I'm going to give a try on the installer right now.. it may just be that there's a missing/damaged skin file in the install.. Have you tried a different skin at all ?
