playlist over 1000 Songs problem any one else?
  • playlist over 1000 Songs problem any one else?
    I am having a problem when I am playing music in RR. On the top of the screen where the track number and the title of the song is at (on the page where your playlist of songs are at).when it gets to a song numbered over 1000 the left and right sides are cut 1/2 way off.For example if song number 2154 is playing half the 2 and half of the 4 are cut off.Sometimes i can get it working but most of the time not even if I restart RR or restart Windows it does not always fix it.I don't know what i do or it might deside itself to work.
    any one else hear of this?
    Any Ideas?
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
    this is a Skin issue.. you can simply edit the audio_player.skin file and change the width of the area used to display the tracknmuber.. You can also use the Skin Editor from another thread to increase the space for the number.
    Now, I know for a fact there should be space to 4 full digits in ther (up to 9999), chances are you simply don't have the Arial Narrow font installed.
    Ride Runner RR's Myspace
      Looks Great now Thanks....
      RR Is The Best Frontend Out There!!!!!!!!!!!!! It Rocks!!!!!!!1
      Does anyone know what the
      car N/A:
      OUT N/A: is used For?
      Thanks Again
      Michael
      1.)Orion 2500d Amp
      1.)Orion 15" h2 Sub
      1.)Orion 8004 Amp
        You should try to do less drugs, its impairing your judgement
        Go on and do it, do it, Do it 'til you're satisfied,
        Whatever it is, do it, Do it 'til you're satisfied.
        CarPc progress |OOOOXCOOOO| 57%
          car N/A:
          OUT N/A:
          Those indicate Temparature!
          if you have an incar and outdoor temperature sensor you can see it there
            it's also possible to display CPU/Case temperature using MBM5 .. for this you have to do some skin editing (.skin file only, no images).. some people use the Case temperature from MBM as the "inside CAR" temperature, which might be reasonably close enough..
            If you wish to remove those labels altogether, simply edit your .skin files and add a / in front of any line that says "TEMPX", "=Car:" or "=Outside:" ..
              I have my case temp and cpu showing the temp in Celsius in RR using MBM5 how do i change to Fahrenheit In RR? i looked around in the forums in RR but can not seem to find anything.i know it probably has been covered before but can not seem to find it. i found this thread
              http://www.mp3car.com/vbulletin/show...ht=temperature
              I know this is a simple thing to do but can not figure it out.
              thanks
              Michael
              also guino check your PayPal Account You've Got Money Today...
              1.)Orion 2500d Amp
              1.)Orion 15" h2 Sub
              1.)Orion 8004 Amp
                well, it seems the harder part you've already done.. all you have to do to show it in F is change the tooltip text to this "c2f" -- so the line would end like ...,"MBM01","c2f"
                That's it.. let me know if it doesn't work..
                PS: Thank you very much for the support!
                  worked perfect.
                  Thanks Again
                  1.)Orion 2500d Amp
                  1.)Orion 15" h2 Sub
                  1.)Orion 8004 Amp
