Playlists & Playlists path
  • Playlists & Playlists path
    Can anyone explain the usage of playlists and the playlist path and how it can be used?
    I'm trying to set up different playlists but struggling ......
    Playlist path sets where your playlists will be saved (as M3U files).. if left blank, RR will save your playlists to your default Music Folder.
    If you have Playlist/M3U files make sure you can access that folder using RR's browser (this can be done by adding a BROWSE.RRL file if needed). When you click Select on a M3U File, RR will load the M3U as your playlist.
    For the SAVE playlist function to work, you must have a skin that has the save playlist function in it (I know of none released with this yet). This is a button with the command "SAVELIST" that brings up the OSK and lets you type in the playlist name to save onto your Playlist path.
    Ride Runner RR's Myspace
